I have a SAMSUNG printer Model MultiJet 4500c.Please advis what color catridge or what number of lexmark I can use for this printer. Chaoho Meng
  • 385 Answers
Hello there,
This printer can use the Lexmark color cartridge # 12A1980.
The black, FYI, is #12A1970.
Thanks,
Lolita
Posted on Apr 10, 2008
Lexmark C510 printer doesn't print yellow color.
Try the old one again. If this works you have a defective new catridge. This sometimes happens.
Feb 20, 2010 | Lexmark C510 Laser Printer
Hi my name is Hector,on my 2.5 inch display it say cartridge erro error #1203. I checked my users guide it dosnt say anything about error numbers.
Error 1203 is a very interesting error code. Here is what I found out about error 1203
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a problem and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
or try this other option:
Dell All-in-One Printer Cartridge Error 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape. I believe this will work on Lexmark printers.
Jan 06, 2010 | Dell 966 All-In-One InkJet Printer
Replaced ink cartridge but printer is not acknowledgeing
wipe clean the tip of the catridge and also the sensor of the catridges. good luck
Jul 30, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer do not recognise color catrige
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 13, 2009 | Lexmark X1240 All-In-One InkJet Printer
I have a carrier Jam!? It a lexmark x5320 I have tryed everything nothing works.
In this case unplug the Power Supply from the Printer...............
Take Out both the catridges from the Printer.................
Move the Catridge Carrier which holds the Catridges inside the Printer from left to right and from right to left for about 20 Times.......................
now insert both the catridges inside the Printer and Plug in the Power Supply and see whether you get the error message again.................
If u still have that error message please Call lexmark:
1-800-LEXMARK (539-6275)
Just call this number because the Enchoder strip has to be replaced........
Good Luck
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
Lexmark z605 not printing colour
may be ur ink catridge is old or colours ower so change ur catridge
Dec 19, 2007 | Lexmark JetPrinter Z605 Color InkJet...
Samsung Multijet FX4200 Fax/Copy/Telephone
THERE IS COMMUNICATION ERROR , PLEASE CHECK THE PHONE LINE. HAPPY FAXNG OMNIPRESENT
Mar 30, 2007 | Samsung HP 4200 Laserjet Printer
41 people viewed this question
k24674
jasbo
jasbo
