Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Hi Slinterio... You helped me a few days back with a Sony HS30 Convergance issue. I have one more question for you if you would noy mind? After looking at the resistors, I can not find any that look bad. I think I should be looking at the 1/4 watt ones. There are also some, like, 1 watt ones. They look ok as well. Have not taken the D board out yet. How should I approach this resistor issue? Should I order a few just to be safe. Or just order the STK's or what do you think exactly? Is it the small ones or the larger ones that I should be looking at? Thank you so much, John
  • 1 more comment
  • pede69 Apr 11, 2008
    Awesome, thank you for the reply.
    If it were you and you seen no signs of burnt or blown resistors, would you just replace the STK's and then see what happened?
    Thanks,
    John
  • pede69 Apr 25, 2008
    Hey...
    I finally got around to replacing those STK's.
    No Change. Don't know what to try next. Many people, based on photos told me to replace the STK's.
    The following url has a bunch of pics I took after I replaced the STK's.
    Would you mind taking a look and let me know what you think?
    Here is the link:
    http://elitewebman.com/sony/
    Thank you,
    John
  • pede69 Apr 26, 2008
    Thanks a ton...
    Check all the smaller 1/8 or 1/4 watt resistors or the larger ones?
    Thanks,
    J
  • Sony Master
  • 8,617 Answers
John the resistors for your model are all 4.7ohm most are 1/2 watt the other few are 1/16 watt but they are all 4.7ohm rated flameproof.
Posted on Apr 10, 2008
  • Sonny Berry
    Sonny Berry Apr 25, 2008
    John check the resistors by lifting 1 leg from circuit and checking them also there are four pico fuses right next to the ICs which may be open Check those as well
Sony kp53hs standby light blinking 6 times
do you have the HS 10, HS20 or HS30 model number with the 6 blinks?
Apr 04, 2012 | Sony Televison & Video
How do i connect pc to sony vpl-hs3 projector
hi,
u can connect the computer to ur projector for that u need Signal interface cable.
its number is SIC-HS30. u can connect one end to the vga out of pc and the other end to pj Multi input of ur projector.
ok
Dec 18, 2010 | Sony VPL-HS3 Multimedia Projector
I have a RCA 61" HD projection tv and the convergance is going wack. I tried to do the auto convergance from the menu screen, but still not working right. What could be the problem?
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via thevoltage on the
color ray gun tubes that get out of adjustment.
They arealso known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Had very similar problem, that blog helped me save
hundred's of $$$$ in repair costs ! :D
Hope the blog helps you also :)
Jean
Jan 31, 2009 | Televison & Video
Convergance issue on one AV input only
This is not a convergence problem in the traditional sense as it would effect all inputs not just one. I would be looking at the video switching IC as the defective part. I'll look up your model to try to get you more details. Are you going to attempt the repair yourself?
Thanks,
Dan
Jan 05, 2009 | Sony KDF-50E2000 50" HDTV
TV has panaramic view
I just replied your question. You can see it by clicking HERE.
Dec 21, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KV-36xb1400 convergance Problem
Its not matter of service code only. You also need service data to fix it. But question is, how data is being corrupted? It seems hardware failure in your TV set.
Jul 31, 2008 | Sony KV-36FS100 36" TV
Wavy Red lines
hi there,
if you are familiar with electronics you can do this :adjust voltage at hight voltage block it has screen and focus written on it and comes from flyback transformer,but be careful cause it can be to dangerous if you touch something else,ah,ah adjust only the one that says screen and has a R on top,that means red,ok,thanks.
Jun 19, 2008 | JVC AV-48WP30 48" Rear Projection...
Replaced STK's : Still have problem. HS30
can you detail your problem pls, so that i could help you.
Apr 25, 2008 | Sony KP-61HS30 TV
Sony HS30 Convergance Issue
The STK ICs are located on the D board their locations are IC801 and IC 802 they are both STK392-560 and you will only have to remove the D board. Usually only 1 or 2 resistors go bad right next to the ICs heatsink. You can get replacements at the following link and they include installation instruction plus free tech support heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
