Question about Car Audio & Video
2000 Ford Windstar car stereo smoking
Hi my precious 2 year old stuffed pennies in my tape deck no problem I thought I never use the darn thing that was until mu unit started smoking! I got the smoking to stop and the screen said CALL. My husband tried to take the pennies out on the right side of the deck then the left side started smoking and he actually saw fire! He unplugged the unit and took out the fuses now I have no radio. Is it cheaper to fix or just buy a unit?
    Novelist:
  • 100 Answers
Unless your car is a collectable or very very expensive, in my opinion, I would buy a new unit. The cost of sending the factory one in and just getting them to check it over isn't worth it. You could probably pick one up from ebay or your local scrap yard. Wether you buy another factory unit or an aftermarket unit, is up to you. Good luck.
-Andrew Hawkins
Posted on Apr 10, 2008
How do I get this device to play and record again? I often clean the heads.
if one reuses the tape often, ive found that the tape stretches and no longer covers the entire record path (or play path) , i still have a few cassette and reel to reel decks that I still use , and since the tapes are hard to find now I keep reusing the tapes more and more 4 the same thing , I guess its been like in the past year ive seen this tape stretching thing happen now
Feb 04, 2016 | Sony TC WE435 Stereo Dual Cassette Deck...
I have had my 1991 lexus ls400 for a couple years now and I've been using the cassette deck in the stock stereo unit all the time by using one of those cassettes with the 3.5mm headset wires coming out...
The tape deck in the unit probably needs to be fixed. Even though you are using an artificial tape supplying a signal to the heads, there are still motors and belts running in the unit if it thinks a tape is in there. Now a belt or a motor has failed and the deck will not stay in tape mode. Thus pulling the unit out of the dash and having it serviced will be required to use this I pod function. There has to be easier ways to do this- I would consult Crutchfield about it.
Nov 08, 2012 | Audio Players & Recorders
My car radio,cd,tape player and clock does not work
hi margie, your fault lies with the power line feeding both your clock and car radio units. check the fuse of the line feeding your radio/clock section. the fuse box should have the areas clearly marked. also check if the ground connection to radio/clock is not diconnected sumhow. if this advice does not help then it wub advisable for you to consult with nearest auto-elecrician. cheers.
May 22, 2012 | 2000 Ford Windstar
Where can I have my 15 year old Sony Model TC-WR465 Stereo Tape Deck Repaired? The problem appears to be mechanical. The tapes will not advance on either side of the unit.
Depend on your location and willingness to ship the unit. The cost of the repair must also be weighed in. If you don't want to put $100 into it I don't think most shops these days will want to open it up. Dual cassette deck are notorious for failure due to cheap design. Look around at all the problems. I have been fixing units for 40 years and even at Sony and Sony authorized.
I can look at it at Skywave Tape Deck Repair in Chicago area if you want. Google it.
Aug 09, 2011 | Sony TC WE435 Stereo Dual Cassette Deck...
Just put an aftermarket stereo in my 2000 ford windstar. I used the specified harness adapater for this vehicle. The new stereo works great. However, now my 2 back speakers dont work at all. What could...
Definitely. The specified harness adapter you used makes no provision for connecting the rear seat control unit. You may be able to modify the adapter wiring to connect to the rear speakers.
Jan 14, 2018 | 2000 Ford Windstar
2000 ford windstar stalls at 2000 rpm some times dies i no its not the dpfe
Good Evening, I have had a few of these on the car lot and noticed a few inherited problems that can cause what you are talking about. First thing is a coil going bad, second is those darn plenum and intake gaskets which cause a vacuum leak which causes the engine to develop a miss not only at low rpm but also at higher. I cannot say that it is your problem without coding it, but give you some insight into possibilities. Hope this helps.
Nov 02, 2010 | 2000 Ford Windstar
I am doing a tune-up on my 2000 ford windstar 3.8v6 are bosch plugs good to use in this van or what is a good plug to maximize gas mileage
Bosch are okey,just use the OEM configuration,not these 4 prong silly things, you see in ads.
Check out NGK-they come with motorcraft and ngk logos,from factory. Now you know who makes Ford Plugs
Two things---
1--you won't improve mileage on a 10 year old vehicle,or a new one,doing anything
2--There have not been Tune-Ups in 25 years,all vehicles are computer controlled,no tuning,no adjusting
You are performing a Preventative Maintainance Service--been that for over 30 years.
Remember OBD1 1980 thru 1995
OBD2 1996 thru 2011
Oct 09, 2010 | 2000 Ford Windstar
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Have a 2000 Ford Taurus and the tape player is not working. I am thinking about buying a new deck but on bestbuy.com they state many of their products do not "fit" my car. Is there any solutions to this?
There should be one that fits in your console. Try to get the exact dimension of the location where you'll insert the stereo on your console and check available stereo head units you would want to install in your car.
^_^
Jun 06, 2010 | Metra Ltd 99-5716 2000 Ford Taurus Radio...
95 Ford stereo speakers stopped working
i'm guessing that is premium sound... check the relay for the amplifier.. or bass booster ... can't remember what it was called on my windstar of that year but when i blew the fuse i had no sound
Mar 23, 2009 | 1995 Ford Club Chateau
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
