Question about HP DeskJet 5550 InkJet Printer
Printer will not print
Changed ink cartridges, ink light will not go out and printer will not print.
  • 1 more comment
  • cinone Apr 11, 2008
    Black ink works. When colored ink is in the ink light flashes and it will not print. Brand new colored ink cartridge
  • erry Apr 18, 2008
    Saame thing. Just replaced black ink cartridge and the ink light keeps on flashing and can't print.
  • labston Liz Jun 23, 2008
    was working until I changed the ink. The paper feeds through but it does not print. The ink carthage is new. Printer is hp deskjet 845c
    Problem Solver:
  • 7 Answers
Reinstall the drivers
Posted on Jun 21, 2008
DeskJet 895Cxi Printer ran out of black ink before my summerholliday. Back on job monday I replaced a new inkbox, HP 45 Black. The colour ink was changed just before my holliday. Still the orange light...
Follow each of these steps until the problem is resolved:
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
http://www.fixya.com/support/t5472914-hp_deskjet_932c_went
Aug 04, 2010 | Office Equipment & Supplies
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Ink light won't go out
It was a problem with the black ink cartridge. I changed it and the printer is working fine.
Oct 05, 2009 | HP DeskJet 932c InkJet Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
We changed the ink and the red light and green
Some times you need to find the epson tools that comes on the CD to reset the printer. If you have upgraded the computer you may need to update your drivers at the epson sight.
Once you have opened the epson tools try cleaning the print heads.
then it should reset the inking system to default and read the new cartridges. If this doesn't work try shutting down the printer and removing the ink cartridges, restart the printer and allow it to find no cartridges the go through the process of reloading the ink cartridges again and cycle the printer.
If this doesn't work you may need to try and find a cleaning cartridge for the print heads. Since the printers always check to see if ink is getting to the print heads if there is no ink flow it will always come up like there are no ink cartridges installed.
Hope this helps
Make sure paper is in properly they can be very picky about that.
Try turning it off wait three minutes and turn back on.
Then
Push Paper refill button Wait for cycle and see if paper light stays off if so...
Push the ink button
Sep 18, 2009 | Epson Office Equipment & Supplies
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
I changed the black ink cartridge and now not working
Did you remove the plastic sticker over the print head of the cartridge?
Are you using a refilled cartridge? Most cartridges have a sensor that tells the printer how much ink is left. When companies refill them they do not replace the sensor, so a completely full cartridge will still tell the printer that it is empty.
Jul 01, 2009 | Epson Stylus C48 InkJet Printer
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Printer prints lightly after changing a cartridge
i guess you have problem with the poor quality ink.
faced same problem.
i re-filled with best ink in the market and the problem was gone..
i hope that helps
Mar 21, 2007 | Samsung SCX-4100 All-In-One Laser Printer
HP DeskJet 5550 InkJet Printer Logo
119 people viewed this question
Seeker5211
Seeker5211
