Need a bios download for maxdata laptop
Hello there i have a maxdata nb vision 340c laptop when i boot up the laptop it says:
ATI MACH64 SDRAM BIOS 4.151(6133-V02)
Bios cant find the MIFLASH.COM file
Please copy the MIFLASH.COM to disk and press any key to retry.
I have looked on maxdata's website and all over the place cannot seem to rectify this problem can you help me download the files i need or provide them please.
  • 2 more comments
  • Anonymous Apr 13, 2008
    hi got the same problem with my topline , i cant find the miflash and my laptop also..
    and i try a lot of websites
  • Anonymous May 09, 2008
  • Anonymous Sep 11, 2008
    i have the same Problem
  • Anonymous Oct 16, 2008
    Ahhh it drives me insane!!
  • 520 Answers
Remove the rtc battery for about 5min then replace this will reset bios to factory standard.(wont need to flash)
its usually located under the keyboard on mother board it looks like a large watch battery sometimes sealed.(covered)
Posted on Apr 10, 2008
How to remove dvd drive
If you remove the drive and then boot the laptop, it will not be there. The BIOS sorts that out.
Jul 17, 2014 | Dell Inspiron E1705, Intel Core 2 Duo...
I may have erased BIOS on my Maxdata eco 4000a laptop. Can it be restored?
Your problem is the boot sector on the hard drive has become corrupt. Nothing to do with the BIOS.
Find yourself a hard disk utility and check your hard disk integrity.
Low level format your drive and reload your Linux
May 02, 2014 | Computers & Internet
Trenger biospassordet til hp pavilion dv 4000
If there is a bios password set and you don't remember it, or you got the laptop from someone else, then you should get a bios password removal software download. Many are downloadable and can be run from a usb or CD. Just google the need for bios password removal software.
Gerald
Apr 28, 2014 | Maxdata Pro 650T Notebook
Dell poweredge 1600sc w/ ATI Mach64 w/ Windows 7 Ultimate highest video mode is 24 bit true color
Bios too old and the 32 Bit system is inadequate to manage the function desired.
Feb 06, 2013 | Dell PowerEdge 1600SC Server
Hello. I'm currently using ATI MACH64 as a standard VGA adapter. When I check DirectX diagnostics, it shows 3D acceleration and 3Draw acceleration as unavailable. I have DirectX 11 installed. I want...
This is an ancient video processor that has no DirectX support whatsoever -it doesn't even have 3D capabilities, it's strictly a 2D chip. You really need to upgrade.
Feb 26, 2011 | ATI MACH64 Graphic Card
Want to re-format MSI Notebook S420. Screen continuously shows windows 'loading' but never boots. I have the recovery CD but because the computer never actually starts, I'm not sure what to do with it!MSI
Hello megan_van
While your laptop is on, eject the optical drive and insert the recovery CD. Turn off your laptop via the power button, and turn it back on. The recovery CD should boot. Follow the on-screen instructions to do a clean install.
If the recovery CD doesn't boot, try holding down the C key after turning on your laptop. If it still doesn't boot, you will have to change the boot order in BIOS. Don't worry, this is easier than it sounds! Follow these instructions:
1. Turn on your laptop, and look for a message that says something like PRESS (USUALLY F2, F8, DEL, ETC.) TO ENTER SETUP / BIOS. Hit that key before the Windows logo appears.
2. After hitting the relevant key, you'll be taken to the BIOS setup utility. All BIOS utilities have different appearances, but it is basically a set of menus containing different settings for your laptops hardware. Somewhere on the screen (usually the bottom), is a set of instructions for navigation your way around the BIOS. Follow these instructions to navigate your way to the option for changing the boot order.
N.B. Since every BIOS setup utility is different, the specifics on where the boot order options are located varies from computer to computer. The menu option or configuration item might be called boot options, boot, boot order, etc. The boot order option may even be located in a general menu like advanced options, advanced BIOS features, other options, etc.
3. Once you've located it, use the navigational controls to place the optical drive above the hard drive (usually the +/- keys). To be certain that the recovery CD boots, it's probably best to move the optical drive to the top of this list.
4. Within the navigational controls, there is usually an option to SAVE & EXIT. Press this key. If there isn't, look for a menu option with the heading EXIT. A SETUP CONFIRMATION box will now usually appear asking you to confrm the changes you've made to the BIOS before exiting.
N.B. The SETUP CONFIRMATION box can sometimes be worded cryptically. Read the message carefully to be sure that you're saving your changes instead of exiting WITHOUT saving your changes!
Your computer should now restart automatically, and the recovery CD should now boot.
Hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | MSI MEGABOOK M510C Notebook
I have aproblem with my Acer Aspire 3100 Laptop
locate the cmos/bios jumper below your memory ddr2 modules (J2) you need to be sure to make contact trought this jumper pe.-with a screwdriver, put back your memory modules and turn on your laptop, this process will clear your cmos/bios memory, you will need to setup your dates.
If this will not work you will need to replace your Mobo because of a faulty, we can replace your Mobo if you are interested:
10001 buckwood ave 79925 El paso tx
contact me if you are interested
support@vcrtech.com
vcrtech@hotmail.com
www.vcrtech.com
Apr 28, 2009 | Acer Aspire 3100 Notebook
I FORMAT A LAPTOP MAXDATA VISION 450T PIII AFTER THAT I LOS DRIV
you should have taken the back up of all your drivers, now download software like driver detective then search specific drivers on net
Nov 22, 2008 | Maxdata Pro 650T Notebook
ASRock K7S41GX Motherboard
Page 7 of the user manual shows you which jumper to change in order to change the FSB; http://download.asrock.com/manual/K7S41GX.pdf
Sep 27, 2008 | Asrock Computers & Internet
Computers & Internet Logo
1,326 people viewed this question
David Payne
David Payne
