Maybe you should have the lower oven cleaned including the gas caps, it may be tideous but worth it. first is to locate the burners, it may be dirty or clogged so the heating procedure is delay and often times consuming.
here i provided you with the manual and go to page 11 to go straight to the cleaning procedure.
download
alternate download
HERE
Hi, you have a problem with your heating element which is gradually fading off, that's why it takes a long time to heat up and as time goes on the heating element will stop working. You have to replace the heating element ASAP...
Take care
I have a GAS oven.
Hi, this is a common problem that happens when the oven gas control valve
is sticking. This can be caused by a weak hot surface igniter or a
defective gas control valve. One thing that you can try(be very careful
doing this) is to give the gas control valve a light tap with something
hard like a wrench when the oven is turned on,igniter is glowing but
the burner is not on. You will need to remove the broiler/storage
drawer at the bottom of the oven. Once you pull the drawer out you
should see the gas control valve at the back of the range. Try turning
on the oven and lightly tapping the valve housing. This may loosen up
any debris inside the control valve housing that might be causing the
problem. If the oven burner comes on then try completely turning the
oven on and back of several times. And when I say completely I mean
turn it on after the igniter is not glowing and burner has shut off.
This works about 30% of the time. If the burner control valve stick
after trying this procedure then it could be the control valve and/or
the hot surface igniter defective. The hot surface igniter would need
to be disconnected from it's harness and tested with an OHM meter. Most
igniters should have a 500 to 700 OHM reading. If you get a reading
that is way off then the igniter is defective and replace it. If the
igniter tests good then the gas control valve is suspect and replace
it. Most appliance parts retailers will test your igniter for free.
When the igniter is on it should glow very brightly. If it is dim then
that is a sure sign it is bad.
Take care
Dear Scrapyourhea,
First ensure that your independent thermometer is working fine. It seems that there is problem with your heat mechanism. Normally this type of problems requires servicing....
Download the manual from given link and go through it. This will tell you the cause for the same.
http://www.retrevo.com/support/Maytag-MGR6751BDS-Ranges-manual/id/23649ci773/t/2/
I have checked the oven with my other themometer before, and it has been close. This is a new problem. Also the fact that things are taking significantly longer to bake and the results are not the same tells me the oven is not working properly. I have read and re-read the owner's manual, and have not found a solution there. I would like to order the part and fix it myself if possible.
I have a GAS oven.
