Question about IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad Laptop Series 1420i
Hello: I have a virtually new IBM Think Pad Laptop Series 1420i and all of a sudden, it went blank, black dead with this message: "Insert System Diskette and Reboot" so i inserted the CD Recovery Diskette and no matter how many times I insert and try, nothing works and that one line message against a pitch black background appears. PLEASE HELP! Thanks, Sally (romanosally@yahoo.com)
    Guru:
  • 1,342 Answers
This page will tell you how to do it.
Click Here
You can also get any drivers or updates you may need.
Posted on Apr 10, 2008
I have installed Ubuntu operating system side by side with xp on my think pad t 43 and start to explore the operating system. In the mean time i have uinstalled the pc doctor application as i have meager...
Its possible that the fault is not the ubuntu or the pc doctor that you removed but just the heat. Try to clean all the dust from the vents with a can of pressed air or with a small vacuum if you can open the cover. After that try again and watch out when you work with it not to cover the vents because it overheats very fast.
Jun 16, 2011 | IBM ThinkPad T43 Notebook
Can I increase the ram in my think pad?
Hello
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
Dec 22, 2010 | IBM ThinkPad R32 2658 Notebook
IBM Thinkpad i series Click Of Death
Go to this site and you can find what you want
www.shopping.com
Jan 25, 2010 | IBM ThinkPad i Series 1300 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
My laptop ibm think pad t 41 how can i get the
hello
You can find your drivers at the link given below.
http://www.ibm.com/products/finder/us/finders?pg=ddfinder
just click the link and after opening the browser just put your model number to search your drivers.
Thank you.
Aug 16, 2009 | IBM ThinkPad T40 2373 Notebook
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
Requird Lan Driver of IBM Think PAD LAPTOP
Drivers for Vista are not available.
You can find all drivers for R50 clicking below:
IBM Thinkpad Driver Download models R50
Feb 25, 2009 | IBM ThinkPad T23 Notebook
My IBM think pad 2373 notebook only starts up for a second
it could be possible that the cpu is overheating might need to change the fan or cooling device
Feb 11, 2009 | IBM ThinkPad T40 2373 Notebook
LCD BLANK
Laptop Screen Dim, Blank Or Black - Notebook LCD Display Monitor ...
Click on the above link/ Follow instructions.....Good Luck.
Please dont for get to Vote.Thank You.
Dec 15, 2007 | IBM ThinkPad T30 2366 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
