Question about Saeco Odea Go
Saeco odea go
My Saeco Odea Go machine was working ok for a few months and from one moment to the other it stopped grinding coffee. It gives me the signal that there is something with the grinder, but I have no idea what. I took out all the coffee-beans, cleaned the grinder part, yet, still get the grinder problem message, and it would not start grinding. Your help would be greatly appreciated!
Thank you,
Nora
  • 1 more comment
  • boulware May 12, 2008
    My Odea stopped grinding coffee. The bean auger turns and the motor whirs, but it does not grind and only hot water comes out. I've vacuumed out the beans and tried to clear any clogs that might be in the grinder.
  • lmuzzo27 Jun 20, 2008
    my machine stopped grinding the coffee suddenly. The coffee comes out like colored water. It makes a strange noise also. I have had this machine only since January.
  • lynn55129 May 25, 2009
    Just stopped brewing, we are getting hot water only. Tried to clean the grinder, no luck. It now just makes a whirling noise, it's not grinding. :(
Try to use another brand and more dry coffee.
Posted on Nov 04, 2012
you can get it here:
http://products.saeco.com/
have a great day,
Michel
Posted on Apr 13, 2008
  • 74 Answers
When the grinder stops to work i would turn the grinder to more coarse. this might help if the case is that it has gotten clogged.
Posted on Jul 11, 2008
How do I descale my Saeco Odea Giro Plus Coffee Maker
do you have a video on how to operate this machine
Nov 27, 2011 | Saeco Odea Giro Plus Coffee Maker
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Nov 14, 2009 | Saeco Odea Go
Need to adjust coffee dose for odea go
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
May 21, 2017 | Saeco Odea Go
Saeco odea steamer is leaking
This is a known issue with the Odea GO. You need to take it in for servicing to get the rubber seals changed. This happened with our maching after about 6 months.
May 10, 2008 | Saeco Odea Go
Saeco odea go, kind request for help
I think your grinder engine is the problem, it can be a sensor too.
Hard to give a solution when i not see how the machine works.
Apr 15, 2008 | Saeco Odea Go
Saeco Odea Go Logo
1,401 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
