Question about Insignia NS-DV2G MP3 Player
Headphone jack problem
Even when I try differing headphones, the headphone jack takes a big of wiggling and proding around to get the sound to come out clearly in both speakers. Can I take it to best buy and get this fixed or fix it myself or what?
    Problem Solver:
  • 12 Answers
Most likely the solder points inside the unit where the headphone jack attaches to the system board have come undone. If you know how to solder, you could open the unit and fix it. If that is not an option, you could resort to using the other headphone jack instead assuming it is not damaged as well.
Posted on Apr 15, 2008
I have a 2002 Chrysler Town & country and I can't get the sound to work for the Vcr/player Without headphones. How do I get the sound without the headphones?
I had one of these and it turned out to be the headphone jack, when you put the headphone plug into the jack it disables the speaker and when you unplug the headphones it enables the speaker. There's a contact in the jack and it is probably stuck to headphones. The jack may need to be replaced. Try and wiggle the plug a few times but not hard as it may break from the curcuit board.
Oct 19, 2014 | Cars & Trucks
My left earpiece in my sentry headphones have no sound. How do I fix this?
Check the plug - it might have a broken wire, by wiggling it in the jack. It could be the jack as well - try another headphone in the jack.
Nov 08, 2010 | Sentry HO900 Headphones
MUSIC HAS NO SOUND
If it's all music on the mp3 player,then try a different pair of headphones. If still no sound, try partially unplugging, plugging in the headphones and try wiggling the connector .If there is still no sound, then try erasing all the songs on it and restore the device. If that doesn't help, then it's probably time to replace the mp3 player since the headphone jack is damaged.
Oct 06, 2009 | Philips GoGear HDD6330 MP3 Player
How do I fix a bad connection with the headphone jack on my ipod touch? When plugged in, the music is static-y. It is definitely the headphone jack that is the problem.
Hi, this seems to happen on a lot of mp3 players , usually when you wiggle the headphone in the jack the sound cuts in and out, its the result of the headphone jack bending the metal contact inside the player or can be due to a build up of dirt/ grime in the socket.The problem generally gets worse as time goes on
if you have tried it with different headphones still get the problem and its still under warranty I would get on the apple site or down to you local apple centre and try and get a replacement.
Sometimes a spray of deoxit (plastic conductive lubricant /cleaner)
in the socket does the trick , but I would strongly reccomend trying to get a replacemnt
Jul 23, 2009 | Apple iPod touch
Acer Aspire 1406 no sound issue
So sometimes laptops play up when the headphone socket gets a bit worn. If you wiggle a headphone jack in the socket (put it in at different angles, and rub around) sometimes the sound will come back.
There are two prongs that "detect" the headphones, and cut the speakers... and if they don't "un-contact" when the headphones are removed, the speakers stay off.
You'd need someone to solder a new headphone socket on the mainboard to properly fix it, but if you wiggle and get the speakers back, they should stay back until you use the headphone socket again.
Apr 20, 2009 | Acer Aspire 1406LC Notebook
Fixed broken headphones but sound quality has plummeted
 it sounds as if the wires are wired wrong . yes it is best to solder the wires.all jacks are the same,yours will be stereo i believe. is the braid attached to the earth point, the two other wires attach to the centre of the plug and the other terminal point. these are right and left.
Mar 10, 2009 | Bose Around-Ear Headphones - Silver
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Jul 01, 2008 | Dell Inspiron 6000 Notebook
Aspire 3680-2574 Headphone jack
did you try another set of head phones? the jack for the headphone where it was soldered most likely broke off you can take apart and try and resolder it.
Jan 04, 2008 | Gateway M305CRV Notebook
Sound problems on my D-NE720
!st, try a different pair of headphones. If the problem persists, the jack is breaking from the PCB and will need to be resoldered.
Sep 17, 2007 | Sony D-NE720 Personal CD Player
Insignia NS-DV2G MP3 Player Logo
247 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
