SATA ports not enabled.
My mother board is Intel D915GAV.
BIOS EV91510A.86A.0482
I have installed an LG DVD burner using an IDE to SATA adapter and cable as the IDE slots are being used. The SATA ports 0-3 are "not detected" in the BIOS. How and where do I enable them to use my DVD drive?
  • 1 more comment
  • dahoov Sep 10, 2008
    My IDE to SATA adapter isn't recognized by the MB! It plugs directly into my hard drive, then the IDE cable is attached as well as the power to the adapter and the drive itself. When I reboot - no SATA drives are detected. What can I do? or is it possible the new adapter is defective.
  • tquick001 Oct 25, 2008
    Had to put in new mobo and trying to use ide to sata convert but BIOS says sata ports not enabled. Drive setting was already enhanced. I also tried setting detection to manual and that gave me an option to "enable Serial ATA." That didn't work either. Any ideas?
  • raju_k88 Mar 02, 2009
    it doesnt work for me
  • 667 Answers
Boot your pc and go into your BIOS. Select ATA/IDE configuration. Select advanced and then drive configuration. Yours should be set to Enhanced ( or Native ). Hit F10 to save and exit or use the top menu. See if this helps. If this did't work you might have a cable that needs a floppy power cable plugged into the hard drive along with others. If this fixed your problem please rate it as fixed. If it didn't just add a comment and I'll be glad to help you further. Thanks.
Posted on Apr 10, 2008
I have D945GCCR intel mother board ,i got an ide to sata adapter to recognize dvd writer ......but mother is unable to recognize it ......r there any driver to may it work
This board directly supports IDE. Do not use the adapter. Use the IDE port on the motherboard directly using a standard IDE cable. Good luck!
Jun 14, 2011 | Intel D945GCCR Motherboard
I have a an INTEL Motherboard Model DH55HC. I am installing a basic Internal DVD writer (DVR-A18M) Interface ATA/ATAPi-7. I have the power cable from the POWER SUPPLY in the correct plug. I attach the...
That motherboard doesnt support ATA it supports upto 6 SATA devices which is actually better and faster. You will need to take your DVD/RW back and ask to swap for a SATA and also make sure you buy a SATA cable and good thing is these are actually cheaper and faster. Its actually a very nice motherboard dont be disappointed. Cheers from Scott and plz vote
Jan 24, 2011 | Intel DH55HC Motherboard
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
I need to know where to plug in on motherboard
If its having sata connection you can see sata ports on *********** board using sata cable
1.Pic of sata cable
2.Pic of Sata ports on mother board
You can connect any one of the ports. and you need to go to bios and enable the sata ports if its not done already..
If you have a normal CD Drive you can connect with IDE cable.
See the pics below
Apr 24, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
How to set as master
u need change in the mother board settings by seeing IDE 0 / SATA 0 , 1 or change in device in jumper settings by seeing in the device cover.
Apr 17, 2010 | LG GSA-H10A Burner
D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Oct 16, 2008 | Intel D845GLLY Motherboard
Intel D915 onboard Audio, Video installation driver
Mar 07, 2008 | Intel D915GAV Motherboard
Detection & installation problem
in bios ide configration selecl ATA select both ur sata HDD will be detected
Nov 28, 2007 | Intel Motherboard
Computers & Internet Logo
660 people viewed this question
David Payne
David Payne
