Ricoh Aficio 1224c
I have a copier ricoh aficio 1224c and it displays error code SC570. How do I clear it
  • yuwanlall Dec 27, 2008
    i have same problem with a Sharp ?AR C250 digital. How do I reset the code, please. Thanks
    yr
  • 287 Answers
Hello billboards,
SC 570 means that despite the fact that the the copier had been giving a "FUSER OIL LOW" prompt in the upper left hand corner of the display for quite some time, the prompt was ignored and now the oil is more than low it is empty. You will first need to aquire fusing oil for your machine.Typically it would be purchased from the same source you would aquire toner as it is something that is consumed as the copier is used similliar to toner. Once you have the oil you will need to replenish the copier's supply of oil. To do this you will need to access the back of the machine. Once you are at the back of the machine,look down to the lower right hand corner. You will see a small square panel with what I would describe as an oversized white plastic flathead screw that needs to be turned counterclockwise to release the small panel/cover. Once you remove the cover you will see a clear container witha black screw on cap. Unscrew it,and fill the container with the oil and stop filling when it reaches the neck of the container. Button everything back up and now you are halfway out of the woods. Now we go to the front of the machine. We need to reset the code. There is a yellow rectangular button above the nine key pad used to enter the number of copies you want. Now that you have located it, press it once and then press the "1" then the "0" then the "7" and then press the round red stop button and hold it down until the screen changes and beeps. At this point the display will have several blocks showing. One of the blocks will say "copier".Press the copier block. Now you will have a drop down menu to the left and several options across the top of the display. At the top,from left to right,the fourth box should say "SP DIRECT" and should actually already be highlighted. At this point,merely press "5810" on the keypad and then press the " # " pound sign. The pound sign means enter. At this point you should see a prompt that says something like "SC reset" and there will be a bar below the prompt that says "EXECUTE" .Press the execute button. This resets the code. But now you must turn the main power off (the red switch located next to your left knee on the front panel of the copier) and wait a few seconds. Now turn that switch back on and you should be good to go. I just reviewed my instructions and wanted to stress that the yellow button above the nine key pad says clear/stop. Just wanted to be more specific. I bet you have this problem whipped in no time! I hope this helps.Take care and good luck.And please feel free to let the folks at "FIX YA" know if I helped you. I don't get paid by them but I like the pats on the head . :-) ...........spinal.......
Posted on Apr 19, 2008
  • Raid Jan 04, 2013
    Thank yoy Spinal, Its Worked ! I have Ricoh 3224c and I did what you say. Every think is fine now, thanks again
  • ann hickling Aug 25, 2014
    It worked yep i am back in business, the instructions was perfect thankyou so so so much
Thank you Spinal, your solution worked out perfectly for me :))
Posted on Jul 02, 2008
Thank you Spinal. This worked for me too!!!
Posted on Jul 16, 2010
  • tnelson856 Dec 13, 2010
    Spinal. You are an absolute Star. Thankyou very much..
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
RICOH AFICIO 5500 - SC555 ERROR HOW CAN THIS BE CLEARED?
press yellow clear then enter 107 and press and hold the orange stop key untill you enter service mode.
select copy sp
press 7807 and then the # key. select execute on the righ on the display
when it says complete turn off the machine from the red power switch. turn machine back on. if error returns repost here .. you may need parts
Aug 08, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
The 1224C Ricoh Photocopier keeps on displaying SC571 error message.
Try 'clear', '107', 'start' buttons. If that does not work, try different combinations, but '107 should be correct.
Jul 04, 2008 | Ricoh Aficio 450 Copier
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
1,531 people viewed this question
jasbo
jasbo
