Question about Philips 23PF9945-37 23" Flat Panel LCD Monitor
TV problem my buttons are blocked and i dont have remote to unblock what i must to do? there is a switch to restore factory setinngs?
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Blocked tv without remote. how to unblock
You DON'T! You need to buy either a replacement or get a universal remote from Best Buy.
Jan 19, 2014 | Air Con 18,000 BTU 13 SEER Mini Split...
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Access code forgotten need to unblock and restore channels
With the remote you can enter a code twice to reset (see pg. 15 of the manual below). It's possible that you can program a universal remote to use the buttons needed to reprogram.
http://www.usersmanualguide.com/philips/tv__4_3_-_tv_medium_20-24_inch/19ps50s
Apr 01, 2010 | Philips 19PS50S 19" TV
Tv wont respond to remote, remote buttons light up but tv doesnt respond
is it the factory remote? if it is check to see if something is blocking the sensor on the tv, clean the sensors, if it is a universal remote alot of new tvs have codes that even some of the new universal remotes dont support. if thats the case you will just have to make do.
Nov 02, 2009 | LG 42LC2D 42 in. LCD HDTV
My remote seems to be blocked
i think they are junk mine did the same and it doesnt get any better . the speakers will start making a popping noise and my hdmi input dont work now so the tv is useless.
Apr 17, 2009 | iLO 3200 32 in. LCD Television
PX- rc1
Basically all it takes to restore the TV to factory setting is to unplug the TV from power and all connecting cables for about 3-5 hours (depending upon your model). This is called a Hard Reset and should restore the TV back to factory defaults.
Oct 23, 2008 | Televison & Video
RCA D52W20 and PS3
I have a problem my tv dont power do you now what can I do?
May 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips 23PF9945-37 23" Flat Panel LCD Monitor Logo
23 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
