Use this link for a picture of your firing order.
Firing Order
The 5.0 is 15426378
The 5.8 is 13726548
Hi, the firing order is ( 1 - 3 - 7 - 2 - 6 - 5 - 4 - 8 )
The distributor rotor turns COUNTERCLOCKWISE
The marked # 1 position on the distributor cap faces to the REAR and slightly towards the drivers side, the engine cylinders spark plug locations are numbered.
The wiring diagram....
The firing order is ( 1 - 3 - 7 - 2 - 6 - 5 - 4 - 8 )
The marked # 1 position on the distrubutor cap faces to the REAR and slightly towards the drivers side
The engine cylinders / spark plug locations are numbered :
firewall
4 - 8
3 - 7
2 - 6
1 - 5
front
If someone has altered the disstributer, pull #1 plug, put finger over hole, turn engine over until compression on that cyl, line up timing marks (ball park only) and rotor will be pointing at the correct terminal for #1 cylinder plug wire connection, in the cap.
1 - 5 - 4 - 2 - 6 - 3 - 7 - 8
The marked # 1 position on the distributor cap faces to the rear and slightly towards the drivers side of the engine
The engine cylinders / spark plugs are numbered : passenger side , front to rear , 1 , 2 , 3 , 4 and drivers side , front to rear 5 , 6 , 7 , 8
