Question about GE JGBP26 Gas Kitchen Range
Erratic Oven temp
The oven temperature is erratic. Oven won't hold at set temp. Sometimes it starts out OK and then falls off, other times it stays low.
I replaced the thermostat - no improvement.
I got out my multimeter and tested the resistance and voltage readings for the ERC on the wiring diagram and technical data sheet. All readings are OK.
No F errors appearing on the clock.
What's next?
Thanks.
  • 525 Answers
Are you using any aluminum foil on the racks? This will interfere with the sensing capabilities.
Posted on Jun 02, 2008
Erratic temperature on Viking oven
What is the complete model number of your unit?
Feb 18, 2013 | Ovens
My GE Profile electric oven keeps shutting off on me, it shows a "F3" code on the screen. What does this mean?
Sorry to read about your problem, I hope this helps you out.
your F3 means: Oven temperature sensor open you cannot reset this type of problem.
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Jan 02, 2011 | GE Profile JTP18 Electric Single Oven
Erratic oven temperature
The ignitor is probably weak and not relighting when it needs to. Replace the ignitor.
Sep 05, 2009 | Ovens
Kenmore gas oven temp not accurate. Could be high, can be low.
the oven themperature needs to be calibrated, the set screw it's in side of the oven knob when you remove it in the senter of the shaft there is a very small screw, turn it , beon that replace the thermostat.
Dec 06, 2008 | Kitchen Ranges
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Temperature is Unstable
erratic temp in oven can also be a bad oven ignitor, usually to low of a temp and not able to stay at temp, too long to preheat.replace the bake ignitor
Mar 11, 2008 | Hotpoint RGB745 Gas Kitchen Range
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44
It was the igniter. The gas would go higher and then lower. The oven would take an hour to heat up. The new igniter did the trick. Thanks for your help and that link to the new part.
Mar 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
GE JGBP26 Gas Kitchen Range Logo
567 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
