Cannot put in a disc message comes up BLOCKED
  • 2 more comments
  • arthurmallon Apr 10, 2008
    philips Player/recorder No. DVDR3380
    Cannot open tray to insert disc message keeps coming up BLOCKED
    please advise
    arthurmallon@tiscali.co.uk
    I was playing a disc, when I took it out I wasn't able to insert a fresh disc.
    please advise
    unable to solve the problem, please refund monies paid
    problem not solved, still blocked, please refund monies paid as per your guarantee of refund if problem not solved
    Genius:
  • 3,422 Answers
some one had enterd a code into your system causeing that problem if you do not remember the code you will have to take it to a techn in order that they lift off the chip and reset it all over.
Goodluck,
Please don't forget to rate the soution
Posted on Apr 10, 2008
    Guru:
  • 1,894 Answers
Solution 1: Most likely there is a foreign mechanical object obstructing the tray mechanism. If, like me, you have kids around every corner then most likely a curious little one has pushed something in to see "just what will happen". With some luck you can solve the problem by opening up the unit (power-off, unplugging first, of course) and doing a visual inspection for what shouldn't be there (pieces of paper, coins, toothpicks, fibres, etc).
Alternative Solution 2: Sometimes what happens is that the tray loading belt slackens over the years (age, humidity, over usage) and fails to respond quickly enough. In the absence of any obvious foreign object(s) this is a likely alternative explanation. Drive-tray electronics (called SERVOS) are programmed to expect timing signals to come within well-defined intervals of time. If this does not happen (such as due to a slack belt), then the condition is registered as an error. Try replacing the belt if solution 1 does not work.
Sharp DVD 'cannot read disc'
Sounds like the laser is bad.
May 29, 2013 | Onkyo HT-SR800 System
When I put a disc into the camcorder it reads "disc error"
My DC10 Camcorder is now coming up with error message 'replace battery pack'. Have done this and not solved problem, will not turn on at all?
Mar 17, 2009 | Canon DC10 DVD Camcorder
DVD won't play
clean the laser lens first
Mar 06, 2009 | Philips DVP3050V/37
CDJ 100 s PROBLEM E-9103 and E-7201
E-9103 is MECHANICAL TIME OUT,
Solution : some object in compartment slot, remove it, or clean player compartment
E-7201 is disc cant be read in 20 seconds,
Solution : Disc has scratch, Replace disc
Disc is dirty, Clean disc
Dj ajay
djajay@inbox.com
Feb 03, 2009 | Pioneer CDJ-100S CD Player
Panasonic DMR-ES30v Combo- Message of "Check disc for error"
Pay TV in Australia will record "no problem" BUT BUT when it is a pay per view or Box Office etc it will be blocked in a similar way as Macrovisin that is recognized in the encoding of the recording device that the signal is passing through. The result point blank displayed you are not allowed to record this program or it is blocked or distorted part of the way through the recording etc...
Dec 31, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Coby Model Number TF-DVD7005
Paul Sim, coby portable dvd player model TF DVD7005 keeps coming up with an error message that says NO DISC regardless of whatever disc you put in, the player comes up with the message LOADING on the screen and then stops after a little will and comes up with the NO DISC message
Dec 10, 2007 | Coby TF-DVD7005 Portable DVD Player
Pump blocked message
next time u clean the filter when it is empty of water. put your finger in the whole and u will find somthing wound round the impeler of the pump remove what ever is obstructing and u will have no more problems make sure u unplug the machine b4 you start doing this good luck
Sep 03, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
DVD message says "blocked"
Jan 27, 2007 | Philips Magnavox MDV530R DVD VCR
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
