Question about Sharp XR-1S Multimedia Projector
Sharp XR-1S White vertical stripe
White vertical stripe on right side of screen on startup. Goes away after around 10 minutes. Only have used about 25% of first bulb. Owned it about 3 years. Stationery installation, good air circulation, no abuse or damage. Am wondering how much this will cost to fix.
  • richmeister2 May 18, 2008
    Projector: Sharp XR-1X. Thin, white vertical stripe about 1/3 way from left side. The rest of the picture is excellent. Less than 1 hour use; it's been stored as a backup machine in case of failure of my main projector during presentations. Had it long enough to be past warranty, even though no actual presentation use yet. When I first tested it after purchase, it worked perfectly. Just tried it today to make sure it, and the backup computer were working -- and the strip appeared. Didn't go away after about 20 minutes use. Any suggestions?
  • 563 Answers
HI there
This could be a costly exercice as this is a common Projector Mainboard failure.
You can either replace the board or have it repaired.
Posted on Apr 11, 2008
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
How to fix a Sharp Aquos LC-40C32U Picture
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
VIDEO DISPLAY PROBLEM FROM SHARP XR-1S LCD PROJECTOR
make sure the resolutions match. change it on the projector.
Mar 30, 2009 | Sharp Notevision XR-1S Slide Projector
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
SHARP XR-1S won't turn on
OK - I've fixed mine (so it looks) - loads of dust inside unit seemed to caused the problem - vacuuming vents (as the manual prescribes) just shifts all the dust inside around and obviously causes some disruption.. solution - remove 4 screws underneath and lift off top (carefully) remove side panel screws (where Av inputs are) again carefully. Now go around each vent at the front, side and underneath and give areal good blow in each a few times. Plumes of dust and rubbish fly out - keep going until it's all clear. Reassemble and fingers crossed. Mine then started up and didn't turn off - there's a horrible burning smell (dust settling near lamp I presume) which is now fading. Been working 30 mins now with no trouble!
Hope it works for you - will post another update if I have any further problems - no news is good news!
Grahamkida
Dec 22, 2007 | Sharp XR-1S Multimedia Projector
Projector
I have a Notevision Sharp xr-1s projector and it wont work with my windows vista laptop. I tried it on my vista pc and xp laptop and it works fine.
Jun 20, 2007 | Sharp XR-1S Multimedia Projector
Sharp XR-1S Multimedia Projector Logo
216 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
