Toshiba 36 inch TV (8 Years Old)
Hello! Our TV is a Toshiba and it is 8 years old. It is 36 inches and the picture keeps going out. Sometimes it shrinks to a smaller screen and sometimes the picture goes out completely. The sound works fine. Is this something that is fixable?
  • ryanjenn Apr 10, 2008
    thank you for your help! it is on the top and bottom of the screen. how do I go about finding someone to fix it?
    Brigadier General:
  • 6,966 Answers
If the shrinkage is just the top & bottom then it is relatively easy/low cost fix. Most probably, a capacitor in the vertical section is nearing end of its life. This would be the biggest of the bunch and would be something like 47uF/50V.
If however, the shrinkage is on all four sides, then it is the master power supply that is at fault. Chances are the main B+ is getting low which cold be caused by the big filter capacitor or an erratic regulator. This is not a simple fix and would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 10, 2008
  • Louie  Role
    Louie Role Apr 14, 2008
    Hi again,
    Your friendly neighborhood electronics repairman should be able to do the job as long as he is familiar and comfortable working with TV units.
Tv_weight, curtis mathis 36 inch tube
Hello
The TV you specifies here [Curtis Mathis 36" picture tube type] has a weight of 150.3 lbs. OK.
Oct 19, 2011 | Televison & Video
My 20 inch keeps turning off and on by itself continouisly is it history of fixable
Have picture,flashes?Yes,it cold sloders somewhere.Take the tv aparts take end the handle of a screw driver,go around hit the pcb to find old soldering joints,resolders these joints.Not, the high voltage it dead,the tv more than 8 years not worth fixing.
Jun 10, 2010 | Emerson EWF2004 20" TV
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Current value of a jvc 32 inch color tv 8 years old
The street value would be 100-150 dollars. If TV is a cheap model or abused or very used, you should pay less.
Consider a Sony or a Toshiba in tube style since all are cheap now.
Sep 27, 2009 | JVC AV-27D302 27" TV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
SONY PROJECTION TV (42 inch)
most sure your tv is getting sick, just kidding
probably convergence problem you may need to call a tv tech
Aug 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
done tv needs professional help. the Electron gun internally is no longer capable of spanning the entire screen. Not likely anything can be done outside of professional help
Aug 16, 2007 | Toshiba CF36G40 36" TV
Toshiba CX36G60 36 inch tv has blinking light
Most likly it is a power regulator problem, and had nothing to do with the Xbox. These sets are common for this BUT it is unfortainate, that most likly you will be surprised when you take the set into the repair shop, on the cost of the repair. In a set this old, I would not evenm invest in an estamate charge, as Im quessing its going to cost between 225 to 300 to repair. Good Luck
Oct 07, 2006 | Toshiba CX36G60 36" TV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
