Question about HP Pavilion dv6000z Notebook
Toshiba Satellite shuts down and won't boot up again.
My Satellite A60-1591ST shut down abruptly and wouldn't boot back up. It would start - to the point that the Toshiba logo showed - then shut back down. The next day it started and ran much of the day. Then at night, it did the same thing again. The next morning it started up, but I have been reluctant to us it. Does this sound like a hardware problem? Should I try reloading the OS?
  • srdjr Apr 10, 2008
    Hi
    Thanks for your suggestions. I'm hoping I can a couple of minutes to try it soon. It also occurred to me that I should clarify that when the computer "shut down", it didn't actually shut down windows, then turn off. The computer just went dead like someone had pulled the plug. When I got it started the next day, I got the message about windows not having shut down properly, etc. Does that change your suggestions?
    Roberto
  • srdjr Jul 15, 2008
    I've tried the system restore and disk check several times now. Each time the computer works for awhile, but then eventually returns to the same problem. The last couple of times I shut off windows update, in case that was creating the problems. (I've had problems after updates before.) Since the shutting down is very intermittent, it's hard to know when the fix has really worked, and when the computer just isn't having the shutting down problem at the moment. Any other suggestions? I've had a lot of problems with this computer. I'm thinking of just replacing it if there isn't an economical solution to the problem.
  • 667 Answers
Have you installed any new hardware or loaded any new software lately? If not you might have some corrupt files. Reboot the laptop in safe mode. Just hit F8 a few times. It should give you a menu. Arrow to safe mode and hit enter. After it finishes booting to safe mode, do a system restore. Click Start>click Start>Accessories>System Tools>System Restore. Choose a date before a couple of days before you noticed anything happening. Restore will take a few minutes. When it's restored and booted, I want you to do one more thing. Click on start>run>type in cmd and hit ok. This will take you to your command prompt. Type chkdsk /f It will tell you it can't run it right now do wan't to run it the next time you start up? say yes. Close the window. Restart the computer and the check disk program will run and fix your errors.
If this has fixed your problem please rate it as fixed. If nit, just add a comment add I'll be happy to help you out more. Thanks.
Posted on Apr 10, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Apr 10, 2008
    No. Still try to do them in the same order and let me know what happens.
My toshiba satellite L455D-S5976 just shut off and won't turn back on what causes this
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Dec 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
My toshiba satellite p755 keeps shutting down
Nov 04, 2012 | Toshiba Satellite P755-S5385 15.6 Intel,...
Toshiba satellite l355-s7915 heatsink location...keeps randomly shutting down
Oct 08, 2012 | Toshiba Satellite L355-S7915 Notebook
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
HP Pavilion dv6000z Notebook Logo
294 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
