Question about Oster ODF550 Classic Cool Touch Deep Fryer
Need the cord for this appliance. It is TA Hsing cord set Type TA35P. Where can I find this item?
Where can I purchase parts?
Try Repairclinic.com most appliances have common cords and handles ...
Nov 13, 2017 | Bravetti Kitchen Appliances - Others
I need a replacement cord for chefs mark 12 in 1 toaster oven combo tb1080
I could not locate the exact replacement power cord for your toaster oven. If the power cord is a plug -in type, you can look on line, do a search " small appliance power cords", but I'm not sure if you will be able to match up the correct cord. I think your best bet is to go to a local. old fashioned. hardware store or to a small appliance repair center. Take the original power cord with you to match it up.
May 29, 2014 | Kitchen Appliances - Others
Trying to set up just the amp & tapedeck of the Sony TA-AX335 integrated stereo system, but can't get the ribbon power cord to work.
Does the deck light-up at all, or is it completely dead? I've found that in aging tape decks, the belts will deteriorate, and change into tar. I've repaired several of the TA series Sony systems, and that's usually the case. If the deck is just 'dead,' I would recommend retrofitting standard RCA jacks on the back of the amplifier. The pins on the ribbon cable are clearly marked on the PC board inside the amp. Then, you could use any deck you want, or even a CD recorder. Hope this helps. :)
Apr 13, 2013 | Audio Players & Recorders
I have a LG 42"-model 42LH20r-ta TV that I bought
how can I do to obtain the afficheur of my LCD LG42 MODEL 42LH20r-ta
May 15, 2011 | LG 42LH30 42 in. LCD TV
Can you change the system from pulse to tone?
Yes. In system programming under trunk type, you can set it to pulse, tone, or call blocking. It's in the 401 section of programming in a TA series system.
Carl
Sep 22, 2010 | Panasonic KX-T7731 Corded Phone
Ilost cd for my sakar kidz digital camera model# 88379-TA
try this http://www.sakar.com/search.aspx?type=sc
type in Kidz in the search criteria
click on view item
click on drivers
Feb 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cord for blacjer & decker
Parts and Accessories
For parts and accessories for your Black & Decker® household appliance, please visit our partner, Fox International, or use the following.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 11:00 PM, E.T.)
(Saturday-Sunday, 9:00 AM to 5:30 PM, E.T.)
Email: applicaparts@fox-international.com
Jan 21, 2008 | Kitchen Appliances - Others
WOlfgang Puck Deep Fryer 1500 watts power cord
Hi - The 1700 watt fryer uses a magnetic release cord set type TA 35 P. If your unit says "use only with TA HSING CORD SET TYPE TA 35P, It should work.
Oct 22, 2007 | Wolfgang Puck Bistro 1700 Deep Fryer
Cord set or cord clip
To alleviate all the confusion, any standard three-prong appliance cord capable of handling 20 amps of current will suffice. Go to your local hardware or appliance repair store and they will have what you need. You need to specify that you have a GAS Dryer, right? That's what it says in the heading. Gas Dryers use 120 VAC, while Electric Dryers use 240 VAC. There's a huge difference in the shape and size of the cords. Hope this helps you.
Jun 23, 2007 | GE DBLR333GE Gas Dryer
Oster ODF550 Classic Cool Touch Deep Fryer Logo
109 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
