Question about LG WM-2277HW Front Load Washer
Cold water runs constantly even if machine unpluged
  • LG Master
  • 43,501 Answers
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing Machinecold water runs constantly even if machine - 2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Asker's Testimonial " Thank you, I was also told that it may be the fill valve?? " - dsmith1695
Posted on Jun 08, 2010
My ge front load washer the water constantly runs even when machine shuts off
Is it HOT! Or is It COLD? Either way your water inlet valves are solenoids. And they get stuck cause they are magnets. So you need to replace both or just the one that feels HOT...Or COLD! The Price is Huge! Hot valves are cheap because they only let in Hot water. It is the COLD one that are expensive for all the Warm, Cool, and 21 other water settings!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Dec 16, 2013 | Washing Machines
Water wont cut off
Does the water run if you push the timer dial in to stop the cycle or does it run even if you unplug the washer?
Dec 31, 2011 | Whirlpool LSR7333 Top Load Washer
The cold water is constantly running in the machine. It runs through all cycles and even when the machine is off.
Water fill valve is bad. This is where the hot and cold water connects to back of washer. Common problem, gets loaded with sediment
Dec 29, 2009 | GE WBSR3140DW Top Load Washer
Cold water constantly runs even when the knob is pushed in to turn washer off.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. The cold side can fail independently of the hot side.
Oct 14, 2009 | Frigidaire FWS833A Top Load Washer
Cold water runs continuously at end of cycle
If yo9u were to unplug the machine at that point and the water continues to run in you have a bad water valve. If it stops when yoou unplug it, it may be the timer. Would have to test to see if voltage is present at the valve in the second scenario,. Water valve part# is WH13x10024 @ $51.00
Apr 08, 2009 | GE WJSR2070B Top Load Washer
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Jan 11, 2009 | LG WM-2277HW Front Load Washer
Cold Water runs constantly even if the washer is off
you will need to replace fill valve where hoses connect probably has sand in valve especially if screens have been removed remove screws in rear of console lift and roll console back disconnect wire to lid switch remove clips om right and left rear corners cabinet lifts off disconnect hoses and wires 1 screw usually holds valve in postion
May 01, 2008 | Whirlpool Ultimate Care II GSW9650LW Top...
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Washing machine
The hot/cold water fill solenoid might be stuck open.  Try banging on it lightly with a hammer and if that doesn't loosen it, replace it.
Oct 09, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
LG WM-2277HW Front Load Washer Logo
47 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
