Question about Liebherr KES3660 Stainless Steel Refrigerator
The drainage hole is blocked and I can't clear it
  • emailalan Jun 09, 2010
    Drainage hole on fridge is blocked. I have used air pressure (from a bicycle pump) but the water still doesn't drain. Will try again, but do you have any other solutions?
  • 1,284 Answers
Hi, this is a common problem with the Liebherr Refrigerator.
You can clear the blocked hole by using a drinking straw to push down the blockages..
That's how i clear mine....
Take care
Posted on Jun 09, 2010
    Brigadier General:
  • 3,513 Answers
Thanks for writing to Fixya.com.
Please use a little air pressure to clear drain lines, than pour a diluted solution of water and a little bleach down the hole water should drain fast and not pool.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Jun 07, 2010
  • emailalan Jun 07, 2010
    Jun 07, 2010 - I have used air pressure (from a bicycle pump) but the water still doesn't drain. Will try again, but do you have any other solutions?
We have a hotpoint RLA 34 ( MICROBAN ) FRIDGE . water keeps seeping into the bottom , under the crisper box tried turnining temp down , made sure it's level , no blocked drainage hole . door shuts tight...
You said no blocked drainage hole, where was the drainage hole that you checked located? Did you pour water down this drain, and furthermore did you check that the water you poured into the drain flowed into the condensate pan on the outside of the fridge? Unless you have a problem with an ice maker leaking water, it sounds very much like you do have a blocked drainage hole, otherwise known as a defrost drain. the drain system begins underneath the evaporator coil inside the freezer, this is where the water that is collected in the defrost cycle flows into a drain tube that leads the water down to the condensate pan. The best and safest way to clear out this drain is to blow it out with compressed air, after you remove any and all ice at the beginning of the drainage system, in other words, the hole located underneath the evaporator coil.
Nov 09, 2010 | Hotpoint RLA31 Compact Refrigerator
Water in doors
Sounds like the door drain holes are blocked look under the door u will see holes that are blocked use a air Line or a pick to clean out the holes the water will drain out
Oct 05, 2010 | 1997 Toyota Avalon
Water appearing on fridge floor because of blocked drainage hole
Clean out the drain hole with a thin flat bladed s/driver then pour some water down the hole so you no you have cleared it.
Sep 29, 2009 | Hotpoint RLA50 Refrigerator
Small puddle of water on floor in front of fridge
there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
May 23, 2009 | Bosch Logixx KDR40423 Refrigerator
Cleaning drainage holes
i think the drainage holes you are reffering to are the ones in the front cowel. You have to remove the wiper arms and the unscrew the cowel to get at the drains.
Dec 11, 2008 | 2002 Dodge Grand Caravan
Bosh logixx 9
probably have something blocking the drainage pump.
  • TURN OFF AND REMOVE PLUG
  • Remove the small circular plate on the front of the washer (turn so the little hole is pointing downwards, then give it a good shove)
  • find the black hose and pull the stopper out: drain the washing water.
  • open the big petrol style cap behind the circular hole.
  • pull the cap out (I had to use pliers to unplug)
  • clear the rubbish you find here (careful could be sharp)
  • put it all back together
  • PRESTO
May 19, 2008 | Bosch Logixx WFT 2806 Front Load...
Liebherr KES3660 Stainless Steel Refrigerator Logo
106 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
