Question about GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload and place in the house. Plugged in, not cooling, compressor started for a min. when plugged in then quit. When I felt the compressor this morning, it was very hot. Any suggestions or how I may fix or a compressor problem,
    President:
  • 834 Answers
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Posted on Jun 07, 2010
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
Hotpoint fzfm151p. Bought a year ago. Worked fine up until I moved this month. My dad placed freezer in garage by mistake. Lights flashed (all) ever since it was in there. I've just moved it into the house...
Freezers have an electric motor within to pump the freezer gas around. Its possible the movement has caused a problem. Get ban appliance shop or tech to check it out.
Dec 29, 2014 | Freezers
My amana upright freezer was working fine, but transported it to another location when I plugged it back in, it started to make a buzzing noise. How do I turn this off or fix it?
Hello....First...when you transported the freezer...you must sure the unit stays in the vertical position and not laying on it's side...back..or front....If the freezer is making buzzing noises...adjust the thermostat setting down until the buzzing stops...and increase the setting gradually until the desired temp is reached...it could take 24 hours for it to stablize...I hope this was helpful.....PEACE.......
Jan 19, 2012 | Amana Freezers
Layed down freezer to transport in car for long journey left 4 hrs before start up working fine freezing but side edge behind door seal feels quite hot since
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
Oct 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Brought freezer yesterday and is not freezing
It is probably out of freon.
Nov 24, 2009 | Freezers
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer quit working
I suspect when you lifted or moved the freezer, you tilted the compressor such that the oil washed out into the refrigeration lines. Common when people tilt refrigeration equipment the wrong way.
Jan 30, 2009 | Freezers
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Not cold enough
HI thanks for your question. start the cooling cycle in the middle so start at 4 or 5 and let fridge cycle, a few times. thanks.
Oct 15, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Fridge and Freezer running, but not getting cold.
make sure your fans are working. one is in freezer section,the other at back by your compressor.
Jan 06, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR Logo
231 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
