Question about Maytag MSD2756GES Side by Side Refrigerator
My Maytag side-by-side refrig is acting weird. The freezer side is freezing alright and the refrig side isn't. Now, I took apart the inside covers on the freezer side and the condenser was all iced up. The fan above it was running fine. I shut everything down to its lowest setting, took a hair dryer and proceeded to rid the condenser of all the ice. I noticed it has what appears to be a heating element under the condenser. I've since returned all setting to their previous setting and I await the results of my test. Now if it starts to cool again, is the heating element, thermostat or a combination of both at fault? I really do not feel like spending all sorts of coin trying to fix this thing. Its an old unit and has served me well. By the same token if I can fix it at a low cost, it'd be better than spending a fortune on a new unit. Thank you
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 16, 2011
Refrigator not cooling.
Are you filling your freezer to full that it isn't able to cool? Maybe you just need to have it serviced filling it with Freon.
Jul 09, 2012 | Refrigerators
Have ge gt mdl# gts22jbpbrww. the freezer is cold but the refrig is not getting cold. I took apart the cover showing me the freezer fan and it is not working could this be why the refrig is not getting...
Yes, if the fan is not forcing the cold air from the freezer section to the refrigerator section, then it will be warmer than it should be. Also check to make sure that the cooling tubes aren't blocked with frost/ice. If you put a hair dryer to the cooling tube openings you should feel the air flow on the other side.
Sep 06, 2011 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
Refrigerator area is freezing, frost forms in the back (not visible) Visible only if you take it apart. temperature goes from 34 to 46 in temperature on a RS257BARB. We took it apart and defrosted back...
the defrost heater under the evaporator in the freezer or if in the refrige section which is a heater grid in front of the evaporator is bad,or the defrost thermostats in either case near the evaps could be bad,or the adaptive defrost controls in the refrige area could be bad too
Aug 01, 2010 | Samsung RS2630SH Side by Side Refrigerator
Helloi have a Maytag Plus side by side refrigerator (about 10 years old) and I'm having trouble keeping the refrigerator side cold enough. This unit has dual slide bar controls on the ceiling of the...
remove the rear panel inside the freezer,your evaporator coil is iced over and cant transfer cold anywhere,deice it,then check the defrost heater under this coil,its probably open and cant heat to defrost the unit
Jul 19, 2010 | Refrigerators
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
My refrig is freezing items on the refrig side.
likely a bad temperature control. also, some model GE's have a bad fresh food inlet cover, that fails to cutoff airflow from the freezer.
Feb 19, 2010 | Refrigerators
Freezer Thaws every few days
It sounds as if the defrost timer could be going bad
May 23, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Refrigerator is freezing on the produce side
if you get frozen fresh food the air damper is not closing allowing too much freezer air to enter ff section, looks like an electronic controlled wide by side you have, ther should be a tch sheet with a troubleshooting guide behind the kickplate or pasted in an envelope under the front of refrig behind kickplate.
Feb 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2756GES Side by Side Refrigerator Logo
66 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
