Question about Samsung HL-T5076S 50 in. TV
I couldn't find model#Hlt5075sx/xaa is It the same as Hlt50765sx /xaa looking 4 part where do I find lamp 4 hlt5075sx/xaa Samsung tv
  • ttrevino12 Jun 07, 2010
    Does Hlt5075sx/xaa and Hlt5065sx/xaa use the same bulb/lamp
  • 10,594 Answers
Required Lamp for Samsung HL-T5075SX-XAA is available HERE for $106 with part number BP9601653A
This lamp also used in HL-T5076SX-XAA and many more models that use same light engine.
Hope these info will help you.
Thanks.
Posted on Jun 07, 2010
  • Shahid Electronics
    Shahid Electronics Jun 07, 2010
    HL-T5065SX-XAA seems incorrect/ invalid model number so I'm not sure about that.
    President:
  • 1,099 Answers
Hello
you can get the lamp at Shopjimmy.com,Ebay.com to buy parts for the replacement.
OR try buy.com/prod/samsung.com
Sometimes the lamp must be reseated
by removing it and reinstalling it with great care making certain
the door and all the gaps are closed tight.
Hope this helps.
Thanks for asking...
I have a Samsung DLP HLT5075SX/XAA and I just replaced the bulb. The tv comes on but it's white with tiny black specs and and two thick black lines going across the bottom. There is no sound but...
The lamp should get very hot---make sure fans are running.
If you happen to remove the lamp---look at the color wheel that faces it to see if missing any pieces--it will before failure make a high pitched or even fan like sound.
You may have a problem in the light engine or the board often called the DMD which is part of the engine.
Jun 13, 2012 | Televison & Video
Have a 50 inch samsung projection tv model hlt5075sx/xaa lamp code bp9601653ap132w turn tv on lamp stays on for approx 20 seconds then 3 blinking lights on right bottom side start blinking if it is the...
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
Jun 16, 2011 | Samsung - Projection TV replacement lamp...
Samsung hlt5075sx/xaa no noise or picture The green light on front flashes 18 times then red flashes once goes through this three times then all three flash then center green comes on constant after that...
That model seems to have had a problem past and I would contact Samsung or a service engineer as it sounds in need of a repair to my mind.
Hope this helps........
Aug 28, 2017 | Samsung HLT-5075S Television
I HAVE A SAMSUNG DLP HLT5075SX/XAA AND IT STARS TO GET BRIGHTS LITLE DOT ALL OVER THE SCREEN WHAT IS THAT IST A PART THAT I NEED TO REPLACE?
Maybe your color wheel breaking up, if hit goes no picture or might be the lamp. If color wheel you can see it if you remove the back panel (UNPLUG TV FIRST) it's next to the lamp. Color wheel cost
Appox. $100 & If Blub Cost $75-$100 both can be bought online. Shop by you model #. If not sure what your doing call TV service Tech.
Good Luck!
Oct 09, 2010 | Samsung DLP HL-P5663W 56" TV
Blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Aug 09, 2009 | Samsung HCM4215W 42" Rear Projection...
Color Wheel installation
You can purchase color wheel of Samsung HLT5075SX from Part Store and I would recommend to have qualified TV tech for installation. it is not advised to novice to get involve in such kind of repair that can damage TV.
Still you want to repair it by yourself then download service manual copy of same TV from HERE for small fee that has proper info.
Aug 05, 2009 | Samsung Televison & Video
HLT5075SX/XAA DOESN'T WORK EVEN AFTER REPLACING THE LAMP.
If you are not hearing a whining noise coming from the color wheel then you have a bad Ballast. Part# BP47-00037A.
Jul 17, 2009 | Samsung HCM4215W 42" Rear Projection...
I replaced the bulb on my Samsung DLP projection TV (HLT5075SX/XAA) but now there is a plastic burning smell. Does anybody know what it can be?
That is probely the smell of the new lamp. If the odor persist and gets worse then remove the lamp and inspect it and the inside of the tv.
Jul 08, 2009 | Televison & Video
Cooling fan motor is making loud humming noise
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
May 18, 2009 | Samsung HL-S5087W DLP TV
Samsung HL-T5076S 50 in. TV Logo
293 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
