Question about Fisher and Paykel DE08 Gas Dryer
SQUEAKY DRUM! High-pitched squeak AKA metal-on-metal as the dryer drum turns.
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerSQUEAKY DRUM! - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Jun 08, 2010
Magic chef dryer making very loud noise as it turns, how to get the bottom off
No need to take the bottom off - the top, front, and back come off - if the noise is a rather high pitched squeak the pads on the drum are worn out, if it sounds like a squeak but more metallic/raspy sound check the motor bearings, also check the drive belt.
Oct 13, 2014 | Dryers
Troubleshooting a problem with high pitched squeaking in GE dryer model PBVH520EJ0WW Squeaks when load is small or nearly dry - repairman came to check it out and said he 'couldn't fi
Could be the bearings going, other possibilities could be that the drum is slightly misaligned and scraping against the housing, although that's not very likely, or a bad belt.
Although sometimes it's some obscure thing, I could be compleatly wrong.
Oct 01, 2014 | Dryers
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Aug 14, 2014 | Kenmore 84052 Dryer
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
Dryer is squeeking
Hi
The motor bearings may be worn. Remove the drum drive belt and then start the dryer. If it squeals with the belt off then the motor bearings are likely worn.
There is a small roller that tightens the drive belt for the drum. They can squeak. Remove the lower front panel and you should see the small roller near the motor and belt.
Another is the two larger rollers that support the drum. You will see this if you remove the front lower panel. Another is where the drum rides on the upper round part of the door/opening and it has a plastic guide that separates the metal drum from the metal door/opening. Over time this wears out and the two metal pieces will squeak.
Please check the bellow links to know detailed idea related to your query:-
http://www.ehow.com/how_5062711_fix-squeaky-dryer.html
http://www.mademan.com/mm/how-fix-clothes-dryer-squeaking.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
High pitch squeak with every turn of the drum
Hello. The dryer has a belt running around the entire tub and that belt also goes over an idler pulley which keeps the tension correct. When you get that high pitched squeak the fix is to replace both the belt and the pulley. If you go to searspartsdirect.com and enter your dryer model number you will get the schematics for your dryer which will show you exactly where these parts are. You can also order new parts from that site if you choose. Regards, Joe
Nov 10, 2010 | Dryers
Dryer makes a high pitch squeaking noise
This could be a dry support bearing, a dried out drum seal or something stuck in the drum seal. If I could hear it I would know better where to start. Listen and try to locate the source from the above list. It could be the belt but that is not as common.
Eric
May 20, 2010 | Dryers
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
High pitch squeak and removal of cloth support
try some felt from fabric store in same place
May 06, 2009 | Dryers
Squeaky dryer drum...felt thing came off how to replace it?
Squeaking is cause by the drum bearing worn out and telling the tale. As it get thinner and thinner it begins to rub against the metal outer casing it is embellished in. To inspect it you must rmove tyhe front and get the drum out. Start by opening the the door and removing the screws holding down the top. Then raise the top and get the screws out thathold the front on. Use the rear acces panel(if applicable) to get the idler loose or access that idler from the front.e24a4b7.jpg
Jan 12, 2009 | GE DVL223EBWW Electric Dryer
Fisher and Paykel DE08 Gas Dryer Logo
374 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
