Question about Canon imagePROGRAF W6400 InkJet Printer
Imageprograf w8400 error message e0200d
I get the message e0200d error on the screen, i've tried remouving the media roll, closed the cover, turned the printer off then back on and tried to put the roll media back on but on the screen appears "load cut sheet" and it doesn't recognize the roll, also the greem light for "roll" doesn't come up at all, but just the one for sheet.
  • 3 Answers
SOURCE: error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Posted on Aug 04, 2008
SOURCE: Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Posted on Aug 19, 2008
  • 79 Answers
SOURCE: i have the canon
check the paper selection button. Is cut sheet or roll paper?
Posted on Oct 30, 2008
Could be that the button for Sheet / Roll has been pressed. This is a popular error caused by the machine expecting a sheet when you are loading a roll. Make sure the light is located on the roll option rather than the sheet.
If this is the problem, you must first remove all media, then lower the covers and lower the media release lever before the printer will allow you to change between roll & sheet.
Posted on Dec 05, 2008
  • 53 Answers
SOURCE: Out of media
Look under the plotter on the control panel side. You will see a sensor with two wires comming out. This sensor is dirty. You can try and blow it clean (often works) or remove it and clean with a small brush. It clips in and out but be careful and take note of the clips etc remove it without breaking any.
Posted on Feb 20, 2009
I get an error messige printhead error, and under this messige it reads: turn power off now before this message it reads for a fraction of a sec it reads offline under this message feed paper arros up...
for drivers go to http://www.usa.canon.com
you will find every driver for free download
after you have made this upload add printer but unziping each file and setting it on your system
under all Programs you will see new programs associated with your downloaded files Next, add Printer from "Start" add printer menu it will auto upload W8400 Printer.
make sure yout canon is "ON" and pluged to your "PC"
after this has uploaded you will see from the programs now downloaded one program called imagePROGRAPH firmware update too, click on the icon close all programs less this page and the program itself click OK and it will search for target printer, if the unit is conected it should show data of the W8400 Canon Printer including firmware, if the firmware reads 2.15 and the year you are in is 2011, then you are uptodate for now, if it reads a smaller number then do the next step, which is goto you printer and switch it off, then press (OK + stop/eject + information) do not let go of the bottons and switch unit ON.
do not let go untill you see GREEN online light come on
you now will see on the screen DOWNLOAD MODE send firmware. walk back to your PC and in the above menu you will see "file - view - printer - firmware - help" click on firmware and send the file.
Make yourself a coffee, by the time you drank it the screen should say load finished and switch off
do that and re start normaly the firmware should have updated. and 2.03 now read 2.15 any other number above this and you may have the wrong frimware.
If the unit still reads Printhead Error, and you see the ink is running okay, not block then it may be something wrong with the heads but if it is blocked place in hot water and you will see the ink flow
dry with paper towel by preding not sliding if you have print head problems still, check circuit conection if there is power comming to the head,
Mar 04, 2011 | Canon imagePROGRAF W8400 InkJet Printer
What does Error Code E02813 mean for a Canon W8400 printer please
How can i do with the error code E02813 on canon machine W8400
Dec 22, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Error code E0200D Have powered off and on says size undetected - any suggestions
danieljudge Thank you!!! You were right! Problem solved. I managed to see that was the problem but didn't know how to change the sheet with the roll. Thanks again!!
Nov 24, 2010 | Canon imagePROGRAF W6400 InkJet Printer
ERRORE E0200D plotter canon W7200
Hi. I have a problem printing the bar code symbol is similar to
Oct 07, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Print head error on w 8400
There could be several problems. One the print head could need replacing. Two it could need cleaning (try doing to B cleanings. Thirdly, it could need adjusting depending on the media one is using.
May 17, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Error message "E02507 No Y ink cartridge"
eplace ink tank with correct 1. trust me. i work for the company
Apr 15, 2009 | Canon imagePROGRAF W8400 InkJet Printer
Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Oct 27, 2008 | Canon imagePROGRAF W8400 InkJet Printer
I have the canon w8400 and when i try to print it comes up error E0200D Size undetected. Pleas explain i have the same problem! it says ERROR EO2OOD. WTF?
Oct 15, 2008 | Canon imagePROGRAF W6400 InkJet Printer
Error Code E0200D
I think making sure the paper is properly aligned fixes that problem. I get it once in awhile.
Feb 19, 2008 | Canon imagePROGRAF W6400 InkJet Printer
Open Questions:
See all Canon imagePROGRAF W6400 InkJet Printer Questions
Canon imagePROGRAF W6400 InkJet Printer Logo
323 people viewed this question
old marine
old marine
