Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Water leaks into bottom of freezer. it re freezes, and then also
Will occassionally thaw and leak onto the floor.
    Sergeant:
    Champion:
  • 218 Answers
there a leak somewhere in there. there is no way you can fix this yourself, call the repairman or LG's customer service.
Posted on Jun 11, 2010
Water is draining and freezing from the freezer and leaks onto the floor
This is an easy fix! First either remove the back access panel or remove the interior freezer access cover. You can reach the drainline from either side. What has happened is your evaporator drain line is clogged. You will need to use a blowdryer to thaw the ice blocking the drain line. The drain line is located at the bottom of the freezers interior back wall. All you will need is a long screwdriver/clotheshanger. Once you have thawed the line stick your screwdriver/clotheshanger and unrestrict the line. I hope I helped you.
Aug 31, 2010 | Refrigerators
Have a TFX26ZPDA that occassionally leaks from front freezer corner. notice of leak anywhere, but find water under the fridge on the floor (facing fridge left bottom)..........why is this
I would check the bottom of the freezer. If its a solid block of ice then you have a frozen drain line. You may have to remove the back panel to access the drain or on some models there is a gap there its located in the back. If you take a turnkey baster and fill it with hot water and keep shooting it down the drain line it should eventually thaw out. The water is coming from your evaporator coils when they defrost.
Hope this helps _MJ_
Feb 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
So water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Jan 27, 2009 | Refrigerators
Water freezing in bottom of freezer
There is a drain for your freezer that is pluged.It may be pluged with ice or dirt.Try unpluging your fridge until it is completely defrosted,4 to 5 hrs. with doors open.
if there is dirt in it it may flush out or your heater element for the defrost is not working.
Dec 18, 2008 | Whirlpool Refrigerators
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
275 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
