Question about Goldstar KG6000R Window Air Conditioner
Window too small
Would it be ok of I put the air conditioner in my window sideways?
  • 420 Answers
Not really, the condenser must be able to draw air from the outside and must stay outside, sideways the A/C will not function properly.
Posted on Jun 07, 2010
3 Suggested Answers
  • 3600 Answers
SOURCE: can I install the unit in the window sideways?
Not really unless you can divertthe hot air from the back side to the outside and and the cool air and intake to the inside, you could do it with some clear tape and some plastic sheeting , but better to build a frame to hold it outside facing in two L brackets then tape it up with some thick plastic.
Posted on Jul 23, 2009
  • 744 Answers
SOURCE: i have a window air conditioner Hampton Bay the
If I understand you, you are trying to install the A/C unit in a sliding window, yes?
They make a window unit specifically designed for these kinds of windows. You cannot use a standard A/C unit and you can't run it on its side.
Posted on Jul 03, 2010
My neighbor below me is complaining that my air conditioner is dripping onto her window. I have had this ac for about 7 years and this is the first year we are experiencing this. Are there any...
Air conditioners work by taking water out of the air, so there is some drainage needed. It is possible your drain line is clogged and it isn't coming out the normal drain. You can also add an extention to the drain line, to get it past her window. Just make sure you route the line no less than one inch per foot drop if you can sideways.
Jun 29, 2011 | Friedrich WallMaster WS15A30 Air...
I have a narrow window. Can an air cond. window unit be put in sideways? panzer12@juno.com
Hello, unfortunatly itncannot be put in sideways because for one it would not cool the room and second it would be very ineficiant.
Jun 08, 2011 | Kenmore Heating & Cooling
I have a window air conditioner Hampton Bay the window only opens to the side and the unit is to wide can i put it on its sideways? Will the conditioner run and be ok like this?
No,it will not,the ac compressor has to be setting the correct way,and the ac line on top of the compressor has to drip,to help cool the compressor,you will have to make the window wider to use this unit,if this was at all helpful,please rate,and thank you.
Jul 03, 2010 | Heating & Cooling
Window air conditioner
Hi, yes you can put a window unit through a wall. Just make sure that the condensation will drain from the indoor coil to the out side which it should do on its own design. Also, make sure that the condenser coil at the rear of the unit is all out side. You will have no problems at all. You can use 2- peices of small chain at each corner and use small lag bolts to secure it to the wall. Looks better then to build a frame to set it on for support. Yes, they are made to install in either place.
Best of Luck,
Shastalaker7
Jun 06, 2010 | Heating & Cooling
Can i install Goldstar air conditioner in the window sideways?
No. This will cause the oil in the compressor to move into other parts of the system where it's not supposed to be. This will cause the compressor to lock up. Also, some units use the condensate water to help cool the condenser. Sideways will kill it.
Jul 30, 2009 | Heating & Cooling
Can I install the unit in the window sideways?
Jul 23, 2009 | Heating & Cooling
I was wondering if you can install the air conditioner vertical instead of horizontal since the window is too small
NOOOOO. The compressor in it is mounted and can only sit one way. If you install it sideways it will burn up the compressor
Jun 24, 2009 | Goldstar R5050 Air Conditioner
I moved and only window in living room is to small
NO! would not drain correctly for starters - would leak H2O everywhere.
May 30, 2009 | Goldstar WG5200ER Air Conditioner
Goldstar KG6000R Window Air Conditioner Logo
96 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
