Question about iLO 2600 Television
Picture tube failing?
I have lines at the top of my tv screen which seem to be increasing and sometimes occupy about 20% of the screen. Is my picture tube failing?
  • 321 Answers
NO thats not the picture ,that is more from the vertical circuit some capacitor defect or the ic it self
hope thet will help you
regards Alan
Posted on Jun 07, 2010
Its really very interesting that this is happening right now to another person, our CRT ilo just started to do the same thing about a month ago. Aside from the lines there's now also a 2 inch black gap (not letter-boxing from wide-screen shows or any thing of that nature) that appears right right after the TV is turned on and sticks around for about 10mins while the picture slowly "fills in" and moves upwards towards the usual, normal, position.
Posted on Jul 02, 2010
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
There's a picture on the screen, but it has lines all across it.Sometimes it will be clear, but most of the time it has lines. I also have directv, but they've installed a new box. Is this my television...
Hello
If the lines are there, and are across the screen at about an inch apart the whole screen from top to bottom, it is due to a slight increase in your TVs screen votage. It can be adjusted.
Open the back cover of your TV. There is an LOT [Line Output Transformer], can be seen directly soldered to the printed circuit boar of your TV. It is the largest component inside your TV, which have usually three wires emerging from it, and one thhick wire goes to the final anode of the picture tube, and will seem to be sticked to the top of the picture tube with the help of a rubber ******. Other two wires goes to the base card of the picture tube, a circuit board.
The said [LOT] has two controls integrated on it facing you as you open the TV. Among the top one is focus control, and the bottom one is screen control. Both of them are variable resistors, help to adjust focus and screen voltages respectively.
As set powered on, keeping the brightness, contrast and colour controls to its minimum, turn the screen control a little bit counterclockwise [not more, a little bit] will eleiminate the lines on your TV screen.
Take every precautions we have to, when working with an electrical equipment. Keep children away from you while you are working on it. Never allow them even to come beside you. Keep an adult beside you as a precautionary measure. Ok.
Wish you all sucess.
Oct 24, 2010 | Sanyo HT28745 28" TV
1. My Sony KP-57WS500 TV is turning blue after abut 3 minutesof operation. It stays that way for about 30 miunes and comes back with pictures again, but with predominatly blue color. 2. Sometimes the TV...
Sounds like the picture tubes are failing,common on sony. do you notice any thin horizontal lines? You mite get lucky and be able to adjust the voltages. Remove back cover and look inside to see which tubes are lighting up.The front panel below the screen will come off and behind it is a small access cover.remove it. there you will find the voltage controls (its a plastic square with 6 knobs). 2 knobs for each tube, 1 is focus the other is the voltage labeled "screen". they are marked so look closely. Green is always in the middle but sometimes they flip the controls for red and blue so pay attention to which you are controlling .slowly adjust screen voltages to see if you can get it to stay on. If you over do it those thin horizontal lines will pop up and the tv will shut off again. If you already have lines back off the voltage by turning knob to the left slowly until they diappear. If that seems to fix it but the problem but it comes back later, then the tubes are shot. good luck!
Jul 05, 2010 | Sony KP-57WS500 57" Rear Projection...
2002 27" SONY Trinitron. Half-screen picture with bright line.
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Sony 36 in.tv
This is usually an indication that the picture tube is starting to fail. A short term "cure" is to increase the screen voltage a bit. This is done by opening up the back and turning the screen control on the flyback transformer clockwise slightly. The flyback if the large part with the red wire coming out of the top that goes to the side of the picture tube. Please note that you only have to turn this control slightly. Ity should be the top control on the two on the flyback. The other is for focus. Also note that there is extremely high voltage there (15,000V) that can be dangerous. If turning up this control resolves the problem, you have bought yourself time to find a replacement only.
Dan
Jun 02, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Top section of the picture gets reversed and compressed
Dear simon, Seems like a simple problem. In all likelihood, one of the Electrolytic Capacitors in the vertical Output stages has failed.It could also be a cold / dry solder, as symptoms seem to disappear when you tap the set. But, do not try anything thing at home. A proffessional Techie should fix it up in 15-20 mins. Definitely worth the spend.
Aug 02, 2006 | JVC AV-27230 27" TV
Televison & Video Logo
326 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
