Question about Toshiba Satellite X205-SLI1 Notebook
I have a Toshiba Satalite X205-SLI1 - Original OS Vista. I want to load Windows XP Pro but when I try to do a new install I get a message "Setup did not find any hard disk drives installed in your computer.
  • Toshiba Master
  • 4,737 Answers
If you haven't any mistakes with the connection, you're going to do a deep research. Your only solution will be from the Bios Settings. This issue is very common for Laptop users; it'll take time but I'll try my best to assist you step by step. I will also suggest you to make print out if you're gonna do it on the same computer you are using right now. Please be patient while I am preparing the tips for you so that you can understand better. Thanks.
Posted on Jun 07, 2010
  • dmartinez043 Jun 07, 2010
    So let's move forward -- what do we need to do to get this system up and running -
  • Lebanon Raingam
    Lebanon Raingam Jun 07, 2010
    This problem
    happens when you have SATA hard drive and you have RAID/SATA mode configured in
    BIOS. There are 2 ways of fixing this problem.
    First method
    is to change the SATA Mode to IDE in BIOS. Enter the Bios Settings, go to “Integrated
    Peripherals > SATA Devices Configuration > SATA Mode
    [RAID] and change to [IDE] A picture is inserted for better understanding;
    (If you are able to change the as instructed above, just save the settings and restart the installation process.)
    If you’re unable to change RAID mode to IDE or disable SATA in
    BIOS, then you need to download SATA RAID drivers from here (please download the first file from the lists), extract the drivers to a floppy disk and then insert
    the floppy to your computer during Windows XP installation (you can also use Cd
    instead of Floppy but on most systems, cd will not support
    for this/will not be detected by the bios).
    Now, insert the Windows
    XP CD and boot it up. You should see a message that says “Press any key to boot
    from CD…” Simply hit any key and it’ll start to boot from CD. Pay attention to
    the next blue colored windows setup screen. When you see a message that says
    Press F6 if you need
    to install a third party SCSI or RAID driver…
    at the bottom bar, immediately hit F6 key.
    After loading some files, you will come to a screen that says like...
    "Setup could not determine the type of one or more mass storage devices installed in your system, or you have chosen to manually specify an adapter. Currently, Setup will load support for the following mass storage devices(s):
    < none >" ..... and so on.........
    To enter floppy/cd with SATA drivers and press S.
    It will present a list of drivers which it copied from the disk earlier. Select
    the appropriate driver and continue the Windows XP installation. The setup will
    continue and this time it will recognize the SATA hard disk drive in your PC.
Does the Toshiba X205-SLi1 have a recovery partition?
Hi joshpop1920,
"Go to this "Website!"
"Download the Manual!"
In the "Manual: search for the {Chapter} "System Restore."
It will explain the: [Recovery Process].
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1854787&rpn=PSPBUU&modelFilter=X205-SLi1&selCategory=2756709&selFamily=1073768663
Mar 12, 2011 | Toshiba Satellite X205-SLI1 Notebook
I have a Toshiba Satelitte X205-SLi1 running Windows Vista Home Premium 32 bit. My computer has been acting up a lot, giving me over 48 blue screen crashes and 15 boot failures in the last 45 days. Does...
http://www.nvidia.com/Download/index.aspx?lang=en-us
I would try uninstall of all Nvidia GeForce software then, go to link above and down load new drivers and install. I put in your info but will outline.
1Product type- click on arrow at right and scroll dowm to GeForce, click on to select
2Product series-click on arrow and scroll down to "GeForce 8m series(notebooks) click to select
3Product-click on arrow and scroll down to "GeForce 8600m GT and select.
select your o/s vista 32 bit, language, then click "Search" this will give you your latest drivers. Let me know the results.
Dave
Mar 12, 2011 | Computers & Internet
Hello. I got a Toshiba m305-4848 pre-loaded
You have to format the drive...Vista can go"over" XP,but XP cannot override Vista.Or partition your drive and get a dual boot system, then you can choose either O.S., like I have.
Mar 22, 2010 | Computers & Internet
Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Nov 06, 2009 | Toshiba Satellite X205-SLI1 Notebook
Getting 3 beeps when starting the comp. with no screen.
some prblm is dere wid d ddr1 or ddr2 compatibility...jst check d compatibility of d ram n insert accordingly..having fit at both ends...that's it...it's not a big issue...
Apr 11, 2009 | Toshiba Satellite X205-SLI1 Notebook
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
Instaling windows xp
when you removed vista then you install Xp your Hardware drivers are not match so you need to install porper harware drivers..
Jul 03, 2008 | Toshiba Computers & Internet
Remove Vista OS and Replace With XP Pro
1. make sure your laptop is set to startup from a cd
2. after laptop finds the bootinfo from the cd and asks you to press any key to start from cd, press any key and xp setup will start.
3. in xp setup your going to need to delete your vista partitions, preferably all partitions and then proseed to install xp into a new partition.
4. proseed with the windows setup follow the instructions and configure your settings as you wish.
Mar 17, 2008 | Acer Aspire 5100 Notebook
Toshiba Satellite X205-SLI1 Notebook Logo
298 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
