Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Sounds like wiring issue to me. I've delt with units like this and there is a wire lead for fan only and a separate one to run the fan when the unit is cooling or heating. I'm only speculating here but I would bet money that this was improperly installed.
Dont get discouraged though because it sounds like its working (for the most part) if you feel up to the task find the manual and check your connections. Otherwise hire a professional.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
You have solved your problem :D You need to get that fan blowing. The vast majority of the time that is all you need. Other times, there can be another part controlling the operation of the fan (ADC - Adaptive Defrost Control). Post the model number and I will see if you have one of these ADCs in your appliance :D
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Check to see if the fan is running in the frezzer side. This is called the evaperator fan and it blows the cold air from your evaperator to the ref side to cool it. If this is not running then your ref will not be cooling at all.
This unit uses the cold air from the freezer to cool the fridge, you will find that the air duct has frozen up, completly defrost overnight with the doors open, this should rectify fault.
Regards
Advisor
