Question about TruTech PLV16320 Television
Does not read DVD, get message WRON DISC
When I put a DVD it spins and hum and come back with message WRONG DISC....same DVD plays in other DVD player
  • Anonymous Apr 24, 2008
    I have the same problem-I insert a DVD-it makes a lot of noise while the player tries to read the disc, then the message states WRONG DISC. I tried using a disc cleaner, as well as checking all of my settings to make sure my kids didn't accidentally set any controls, but it still won't work, and hasn't since about 6 months to a year after we got it.
    President:
  • 814 Answers
The problem is with the disc players laser tracking system. You may still be able to repair it by taking it apart and doing a though clean of the laser and the disc transport system. This requires that you have the proper tools and work space to open up the television and take out the disc player transport and work on it.If this seem over your head as far as working on it . Try to find a school in your area that is teaching television repair and other products. Find out if they allow people to bring in their televisions for repair at the cost of parts only.If they do then allow them to work on you dvd player and hopefully, they can find the problem and repair it for you at low cost. If you cannot get the school to help you, maybe one of the teachers or students can help you with your problem. I hope this helps you with your problem.
Posted on May 17, 2009
When I put in any DVD Disc, you can hear the disc spin. I opened the unit and put a disc in and could see it spin and you can see the laser light come on to try and read the disc. After about 10 sec or...
Is this a blueray player? If it is, the disc you put in probably isn't formatted to the blueray. If it is a standard dvd player there is probably something wrong with the player. You have two options. One, to take it in for service or two, to get another dvd player. If you have another dvd player in your home, try the disc you can't play from the one player and put it into the working player. If that works, then something is wrong with the dvd player you are having issues with.
Apr 03, 2011 | Televison & Video
The disc spins for a long time and then wrong disk message shows it plays cd's ok.
Check ur DVD disc have scratches or cracks that the laser head can't read.Tries to wash the disc with dish washing soap to get clean surface to leaser head to read.Use other Disc see it have same probblems?Check the region of the disc is on the lable like NTSC or PAL.Euroupe and Asia run only in PAL. U.S.Canada,Mexico run on NTSC.
Feb 10, 2010 | Lenco DVP712 7 in. Portable DVD Player...
Disc spins, then " Type of disc can not be played" message
it means the format of the type of cd u put in cannot be played by the system.
try playing the disc it on another player, if it does the same, it means the disc cannot be played. some players dont play mp3 format, blu ray, and some others, so you can check the kind of disc you want to play on it.
goodluck
Feb 03, 2010 | Panasonic DVD-S25
Code H02
Your DVD player is having an issue with the spindle motor (the thing that spins the DVD around). The following solution works for most people, and you should only have to do this once.
  1. Unplug the DVD player.
  2. Take the cover off.
  3. Place a disc on the spindle.
  4. Put a little pressure on the disc (so it doesn't slip) and spin it around a few times.
  5. Remove the disc, reassemble, and plug back in.
  6. Try to play a DVD.
  7. Report back if this solved your problem, or if more troubleshooting is needed.
Aug 02, 2009 | Panasonic DVD-S55 DVD Player
Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Nov 16, 2008 | Audiovox D1020 Portable DVD Player
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Dvd player not working
buy new one then replace it with the old one and take it back for refund
Oct 30, 2007 | Durabrand DVD-1002 DVD Player
Problem loading dvd
replace the lens of your dvd your problems solve
Sep 18, 2007 | Mustek PL-407H Portable DVD Player with...
DVD pLayer Not spinning DVD's
if your dvd player is 5 years old or more i suggest you trash it and get a new one but if its not try to clean the lens manually with a peace of bond paper. rub the paper gently on the surface of the lens
Jul 13, 2007 | Sanyo DWM-3500 System
TruTech PLV16320 Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
