Question about Frigidaire GLTF2940ES Front Load Washer
My GLTF2940ES0 WON'T START it's cycle. An error code "ddo" displays
    President:
  • 1,382 Answers
The meaning for ddo error means "Dispenser Drawer Open"
To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Posted on Jun 07, 2010
What is18h code on gltf2940es0?
Thank you for your post, Jeff Duvall!
I see that your Frigidaire washer is displaying an error code of "18h". However, it appears "18h" is an invalid error code. In order to clear any false error codes, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for approximately ten minutes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "18h". I look forward to assisting you. -Matt
Nov 09, 2014 | Frigidaire Washing Machines
Error code DDo ON A FRIDGEDAIRE FRONT LOAD WASHER
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
Apr 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire GLTF2940ES0 displays LOC when i press start
Hello & Welcome to FixYa
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
My GLTF2940ES0 displays LOC when i press start
The control lock feature has been turned on. This prevents someone from accidently changing the cycle or starting one. To toggle off the lock, press and hold Options and Select until the lock indicator goes off. (Holding the buttons will toggle the lock back on.) If you look closely at the Control Panel, you will see a small padlock icon with a line between the two buttons that set the lock.
The manual for the GLTF2940ES0 is available here: http://www.frigidaire.com/manuals?model=GLTF2940ES0 . The direct link to the manual with information on the control lock is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134457800ef.pdf . See page 3.
I hope this helps.
Oct 02, 2011 | Frigidaire Washing Machines
Our Frigidaire GLTF2940ES0 washer was in spin cycle with 7 mins to go when is just stopped. No specific error code other then Err. It will not start at all now. Door locks and unlocks fine.
Sounds like the electronic locking mechanism is malfunctioning. It is secondary lock which is supposed to enguage before the high spin cycle. It is about a $20 part.
Sep 15, 2011 | Frigidaire GLTF2940ES Front Load Washer
Error code ddo will not start wash
This indicates a problem with the door interlock switch and until resolved the machine will not start.
Sep 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Cycle won't start, error "ddo" displays after about 30 seconds and also code E14
Your dispenser drawer has a magnet in it that has to line up with a sensor. If you can put the drawer back in that will solve the problem, if the magnet isn't lost.
Jun 10, 2008 | Frigidaire GLTF2940ES Front Load Washer
Our washer has an error code of DDO.
ok if it is the rigt thing for that code there will be a switch on the door have a pen or some thing you can use to trip the switch to thinking the door is closed. and unplug the unit and replug it in.. todays age every thing has to rebooted
Dec 16, 2007 | Frigidaire GLTF2940ES Front Load Washer
Error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
378 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
