Question about General Electric WBVH5100HWW Front Load Washer
I have a GE model #WBVH5100HWW front loading washing machine. There is a rip/hole in the rubber lining around the inside which is allowing water to leak out of the washer. Can this rubber lining or seal be replaced?
Crecco610@gmail.com
Posted on Apr 28, 2012
  • Crecco610 Apr 28, 2012
    Tell me how much a rubber seal costs and how to fix it thanks.
  • diamond27265
    diamond27265 Oct 15, 2012
    I bought mine off EBay for $60. A little work to replace, but can be done.
Yes it can be replaced, good luck though. we have bought a new machine because we have had two seals tear.
Posted on Jan 16, 2011
My washer WBVH5100HWW will not fill with water. How do I bleed the air from the water lines?
Any air in the water lines will go on through if everything is working as it should.
Have your pipes froze recently? If so, check the screens in the fittings on the back of the machine where the hoses attach, they may be plugged with minerals. If so, purge the line well into a bucket before hooking it back up.
lp
Jan 11, 2011 | General Electric WBVH5100HWW Front Load...
Water has leaked from bottom
do you mean from the bottom of door? if so open door and run your fingers around the rubber gasket to see if there is any forign matter or rips, and check the small drain hole on the inside bottom of gasket, if there is a tear you could repair with a bicycle innertube repair patch
Nov 08, 2010 | LG WM-2277HW Front Load Washer
Electrolux EWF1074 front loader ripped rubber
i would get the rubber bellow replaced asap as water will be running onto components causing short circuits
May 18, 2010 | Electrolux Washing Machines
GE WBVH5100HWW front load washer stops at 1
It appears that you have an electronic control board (directly behind the touchpad) issue. Contact an appliance service company.
Apr 13, 2010 | GE Washing Machines
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Sep 27, 2009 | GE WBVH6240F Front Load Washer
Fabric softner still in compartment after wash is completed
take out soap box first and clean,i would say that water valve coil is probably blown though,should read around 3kilohm resitance checked when unplugged hope this helps
May 06, 2009 | General Electric WBVH5100HWW Front Load...
Bad smell from washer
Hi Six,
Yeah, that's a common complaint on FL washers. I experienced it first hand myself! (I have a Whirlpool FL washer). I use this in mine about once a month and it's worked well for me. I don't have to order it, though. I pick mine up at my appliance parts place. If you have one nearby, I'd check there first.
SG
Mar 30, 2009 | GE Washing Machines
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
Front loading ge washer model wbvh5100hww
I had to have repairman out. He said it had a filter in front panel that needed to be cleaned. It was full of hard white stuff, like caliche dirt. He noticed I use Arm & Hammer Detergent and he said that was good, but don't use HE detergents because when they mix with city water, it causes an odor in washer. Thanks- Beth
Sep 14, 2008 | LG WM-2277HW Front Load Washer
GE front loader washer soap inside door
You can try using soap powders for 'front loading' machines......
Mar 03, 2008 | GE WSXH208A Front Load Washer
General Electric WBVH5100HWW Front Load Washer Logo
445 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
