Question about Kenmore 36665 / 36669 Gas Kitchen Range
Oven gets red but won't light - Kenmore 36665 / 36669 Gas Kitchen Range
  • 5,911 Answers
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface igniters work and the broiler still works, the problem is not a gas related issue or a control board issue. More than likely, you have a weak or failed oven igniter. Igniters grow weak with age and occasionally need to be replaced. Just because an igniter glows, does not mean it is good. If you are experiencing longer ignition times, or no ignition, this is most likely the case. The following link explains a little theory about these igniters and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
If you have any questions please post back with a complete MODEL NUMBER and let me know. The model number should be listed around the oven door or lower drawer opening on a Kenmore. I hope this helps you.
Posted on Jun 07, 2010
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
I melted some butter in the oven, it dripped into the burner holes and now they won't light.
i would let do this by specialist,to clean the burner.
butter can also ignite or you can get gas bubbles,not safe
Jul 26, 2012 | Stoves Ovens
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
GAS TO STOVE WAS TURNED OFF FOR COST SAVINGS BECAUSE NOT USED. OVEN PILOT LIGHTS WON'T LIGHT CAN'T SEE WHERE HOLE FOR LIGHT IS SO TO BE CLEANED??IT LOOKS LIKE A BLEEDER VALVE FOR BRAKS IS HOLE AT...
To light those pitots remove oven floor& access panel below the doors,for each oven will be a gas valve inside of the panel below the doors and has a red button. push that red button,light pilot inside of oven near the main burner,hold red button for 30 seconds and releas.Pilot should be on,repeat for other oven. If pilots go out after red button was held down for 30 seconds the part called the thermocoupler will need to be replaced
Aug 18, 2011 | Garland H283 Gas Kitchen Range
Jenn air gas oven won't light off/heat up
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 13, 2011 | Jenn-Air Ovens
Whirlpool electric oven won't heat just barely
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then test the door switch. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Whirlpool RBS305PD Electric Single Oven
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
I have a Tecnik TKC 8522 double oven - I can't get the bottom oven to heat up. When you turn it on the fan comes on, but the red light doesn't come on and the oven doesn't heat up.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
Sep 25, 2010 | Tecnik TKC8522 Electric Double Oven
OVEN WONT WORK
Even though the igniter is red, if you are not getting gas it is almost 100% sure that the igniter is simply not getting hot enough. A new igniter should get that valve to open and you will be baking like crazy.
Nov 30, 2009 | Maytag CWG3100A Gas Single Oven
Kenmore 36665 / 36669 Gas Kitchen Range Logo
87 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
