Question about Euro-Pro 377 Mechanical Sewing Machine
Needle replacement type
What is the needle that is used in EP 377 models? Need to purchase replacements.
  • 2,272 Answers
For LIGHT WEIGHT Sewing like as follows:-- Sheer cottons, Silk,Synthetics, Georgette Fine Silk,Fine Cotton,Fine Synthetic,Fine Cotton Covered Polyester. You can use needle size :--9 or 11. ---------- For MEDIUM WEIGHT Sewing as follows:-- Medium Weight Cottons, Synthetics, Poplin, Velvet, Light Weight Woollens 50 silk,50 to 80 Cotton,50 to 60 Synthetic, Cotton Covered Polyester You can use Needle size:-- 11 or 14 For HEAVY WEIGHT Sewing as follows:-- 50 Silk,40 to 50 Cotton,40 to 50 Synthetic,Cotton Covered Polyester Heavy Weight Cottons, Denim Tweed, Gabardine, Drapery You can use Needle Size:-- 14 or 16. ---------------- *Use the same thread for needle and bobbin. Note: *In general, fine threads and needles are used for sewing thin fabrics, and thicker threads and needles are used for sewing heavy fabrics, Always test thread and needle size on a small piece of fabric which will be used for actual sewing. *When sewing stretch, very fine fabrics and synthetics, use a Stretch-needle. The STRETCH needle effectively prevents skipped stitches. *When sewing very fine fabrics, sew over a piece of paper to prevent yarn distortion. --------- Procedure to change the Needle is as follows:--- CHANGING THE NEEDLE 1. Turn the balance wheel towards you until the needle is in its highest position. 2. Loosen the needle clamp screw by turning its top edge towards you. Remove the needle from the clamp. 3. Place the new needle into the needle clamp with it s flat side facing away from you. Push the needle up into needle clamp as far as possible. 4. Tighten the needle clamp screw firmly. --------- TO SELECT A SUITABLE NEEDLE:-- A number indicating the size of needle is marked on the stem. The higher the number, the thicker the needle.
A Stretch needle is recommended for stretch fabrics. Do not use any needle which is bent or blunted. ------------ If in case you require the user manual for your sewing machine EP 377.Just click on the above mentioned link aeec-4479-96f8-650709d6d81e.pdf">http://dl.owneriq.net/1/1e05c7f8-aeec-4479-96f8-650709d6d81e.pdf
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 07, 2010
What is "needle maintenance?"
Using correct needle for job and not bending it.
Aug 27, 2017 | Sewing Machines
How do I change a needle on a brother 770?
same old way as all machines loosen the screw/clamp and pull it down
Feb 12, 2015 | Brother PE-770 Embroidery Machine
Singer CG500 Needle hits the needle plate. Needle was replaced. Verified needle in correctly. Tried hand wheel - still hits. Machine has yet to be used!!
Unless you need all the bells and whistles to sew get you a pre-1930 treadle or handcrank. I have 2 electric Singers, 1947 model 66 and 1948 201-2 both with attachments. Also I have 1903 Singer handcrank made in Scotland. The plastic new one just don't have the ability to hang in there .... All my pre 1930 Singers sew... I love them!
Apr 17, 2014 | Singer CG500 Mechanical Sewing Machine
Remington stitch mate
Hi Bobby B,
Do you just need new sewing machine needles? There are so many types it is dizzying. Go to a place like Hancocks, Joann's or Hobby Lobby. They will be able to help you. Nearly every type of fabric has a needle that will work the best with it. Good Luck! The needle most used is a 80/12. That is the standard needle.
Apr 13, 2014 | Sewing Machines
The rear needle on my EA 605 broke and I replaced it with one I use on my Juki . This is not working. Can you advise?
You need a BLx1 type needle for the Baby Lock EA605. This is a different type of needle than on most other sergers (even other BabyLocks). The only Jukis that use this needle are MO-102, MO-103, MO-104 & MO-134. I'd guess your Juki is not in that list.
Several sites have the appropriate needle. This is one vendor who has them in stock: http://www.sewingpartsonline.com/needle-10-pk-organ-necchi-blx1-11.aspx .
I hope this helps.
Jul 19, 2011 | Baby Lock Imagine
I do not have the manual for our Singer Touch & Sew Deluxe ZigZag model 640 sewing machine, serial # AS056384. It breaks the needle when we use it. Is there a special needle that we need to use or is...
Hi
You can get a replacement manual for your machine from the Singer site, but they cost around $15.
http://www.singerco.com/accessories/manuals.html
Just type in the model number (640) and click on search.
The Singer site have a usefully FAQs section.
http://www.singerco.com/support/faqs.html
Just click on the question My needle keeps breaking and the answer will appear.
Hope this helps!
Nov 25, 2010 | Singer Sewing Machines
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Friends broke needle on my euro pro multi stitch sewing machine.
According to Euro-Pro.com
Where can I buy new needles?
Answer: The needles are universal and can be purchased at any sewingmachine notion department. The size and type of needles should beappropriate to the fabric used. See the needles and fabrics chart inyour instruction book.
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
has all the information including a downloadable manual (pdf file)
Jan 24, 2009 | Euro-Pro 9120 Computerized Sewing Machine
Euro-Pro 377 Mechanical Sewing Machine Logo
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
