Question about HP Vs17 17" LCD Flat Panel Monitor
Blank screen my computer has a blank gray screen tried taking out battery and didnt work tried to charge didnt work
  • 11,361 Answers
Is this lap top? If you just have the screen glowing without any pictures, you need to check the ribbon cable at the LCD panel T-CON bd.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Hopefully it did not blow the fuse on the T-CON bd.
Posted on Jun 07, 2010
P100 was working took 1 picture and froze open. white screen won't charge
Perhaps you have an empty battery?
Just remove the battery and try charging it on an external charger. When it is charged, try again. The camera should start with retracting the lens. Perhaps you again should power down and remove the battery for a few seconds after that, but just try it.
Switching of a camera causes it to start again, like a cold boot from a computer.
Monitor your battery, because if the camera shuts down very soon after that, perhaps you need a new battery?
May 05, 2014 | Nikon Coolpix 4600 Digital Camera
Ipod has locked up with a blank grey screen
how old is the battery it might need to be replaced
Charge the iPod
If your iPod touch suddenly goes blank while you are using it, the culprit could be a low battery.
Prior to the screen blanking you may see a low battery indicator.
If the screen is completely blank, try plugging the iPod touch into a power source and letting it fully charge before attempting to use it again.
Restart the iPod
If you've got a white or gray screen, try to restart the iPod.
Sometimes a simple restart will solve the problem that initially caused the white or gray screen, and the iPod will work as expected once you have turned it off and on.
Reset the iPod
Resetting the iPod Touch goes a step further than just restarting, and it is a good option if you've charged the iPod and restarted and you're still seeing a blank, white or gray screen. Press on the "Sleep" and "Home" buttons simultaneously for at least ten seconds before releasing the buttons. At this point, you should see the logo or a battery icon, if the phone needs to be charged.
Restore the iPod
If nothing else has worked to remedy the malfunctioning screen on your iPod touch, try restoring the device. Connect it to your computer and open iTunes, then click on "Restore" which is found under "Summary." Be sure to back up your files when prompted, because the restore will change all of the settings on your device back to the factory default.
If even this does not work, you almost certainly have a hardware issue, and will have to take the device to an Apple store for examination and possible replacement.
hope this helps
Oct 06, 2012 | Apple iPod touch 4th Generation MP3 Player
I have a Acer Aspire 5610. A few days ago I turned it on and the screen stayed blank/black witha full battery. After trying a few times of trying this I plugged in the power lead and tried and it worked....
could be damaged, try calling geek squad or taking back where you got it. when my dell acted up i called them directly despite purchasing from best buy. they didnt charge me a dime.
May 06, 2011 | Computers & Internet
Blank Screen on Garmin C330
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Phone doesn't turn on, randomly shuts off
This same problem hapnd 2 my fne i bet the smaller screen at the front dosent work either well the problem is the wire connecting from the screen to the main part isloose try tightening it,if this does not work squeeze the screen/middle part conecting the two
Aug 24, 2008 | Motorola Mobility RAZR V3
Go Gear Trouble
Try this:
Make sure the GoGear is disconnected from the computer
Turn the goGear off
Hold in the volume + button
Reconnect the goGear to the computer while holding in the volume + button
Continue holding the volume + button for 20-30 seconds until a "Found New Hardware Wizard" window pops up
If this does not work, the GoGear is toast, call 1-888-PHILIPS and see if you are still in warranty
Apr 13, 2008 | Philips GoGear HDD6330 MP3 Player
My phone stopped charging
Hello
Please follow instructions here. I just tried it with my Razr, and it worked!
Let me know if this works, if not we will look for another problem.
Thanks
Brian
Jan 09, 2008 | Motorola Mobility RAZR V3c Cellular Phone
HP Vs17 17" LCD Flat Panel Monitor Logo
77 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
