Question about JVC AV-65WP55 65" Rear Projection HDTV-Ready Television
JVC 65" AV-65WP55 problem
When I turn the set on, I get a blip of sound then the green indicator light goes into a continuous blink
RED IS RISING UP IN THE PICTURE
Posted on May 26, 2008
JVC Modle HD-61FN97 2006 65 inch tv light went out replaced it now can not adj brightness
Aside from the customer controls you might be able to turn the screen controls up a bit to get more brightness, they are on a black block inside the set.
Nov 29, 2012 | JVC AV-65WP55 65" Rear Projection...
The colors are blured i for instance when i turn up the volum the indicater is red green and blue and there are three indicators for the volume each in one of the three colors
Ur tv have a problem known as convergence problems,it dead.The tv convergence board have the 2 STK convergence ICS and some or all it resistors are dead.All these parts on the covergence board must be replaced to solved convergence problems.The shop should cost u $300-350 for parts and labors.
Jun 23, 2010 | JVC AV-65WP55 65" Rear Projection...
JVC 65 inch AV-65WP55 tv, the color red is failing
The tube is old. You need to contact a service center. He may try to boost it from inside. If it doesn't work, then need a new tube.
Jan 09, 2010 | JVC AV-65WP55 65" Rear Projection...
My JCV av-65wp55 I have a issue when I turn it on it works fine for a while then the picture startes rolling with lines going accross the screen. I can turn it off and wait a while and the picture comes...
A number of this type of JVC projectors had issues with defective soldering to a large capacitor on the pc board in the power supply which could cause such an intermittent prob. Some models also had a similar issue, but one lead of the capacitor was actually broken when inserted at the factory. You would need a tech to look at this, unless you are capable.
Nov 19, 2009 | JVC AV-65WP55 65" Rear Projection...
Jvc i art av 36f475: no sound
Good Day sir/maam, my guess are several, lets start at the common ones, make sure that the AV cables are good. you can try swapping cables to make sure. If possible try the cables on other units such as any DVD player. There is a possibility that the sound jack, is bad, try to vibrate the plugged cable, and see if the sound goes back if it does, you need to solder the terminals. Worse is the Amplifier section of the TV. does the TV sound normal on broadcast? check the volume, mute. or the TV setup. hope this helps. if you have additional info please feel free to ask again, let me know any progress. thanks
Jul 28, 2009 | JVC AV-65WP55 65" Rear Projection...
65 in.JVC bad picture
You may have a convergence problem that means, there may be convergence ic's bad or related components.
If you know something about tv's, try checking things out.
You can get a repair manual from websites to download.
If you do not normally fix tv's the best thing is to call a tv repair technician.
Feb 22, 2008 | JVC AV-65WP55 65" Rear Projection...
Jvc av-65wp55
thats how my stared than got worse i call for service and got fix after 4 moths had the same problem and i called the same guy again at firs he told me that the convergence was bad and replaced them i think there are three pieces but than the second time he took the box inside the tv he checked all the circuits and the board and he found out the something else was getting real hot and was causing that the convergence to bad now he fixed hope i got no more problems
Dec 23, 2007 | JVC AV-65WP55 65" Rear Projection...
Wierd color problem. JVC AV-65WP55
Dec 11, 2007 | JVC AV-65WP55 65" Rear Projection...
Flashing Power Button
the flashes are a diagnostic blink code, tells a tech what the general area of the problem is, you of course have a shorted or open component in your set but thats all I can tell you because you didn`t give the blink count,
Nov 27, 2007 | JVC AV-65WP55 65" Rear Projection...
JVC AV-65WP74 65 in. Rear Projection... Problem:
I'm having a problem with my JVC 65WP74 the screen shows double pictures at the top and in the middle.
Oct 10, 2007 | JVC AV-65WP55 65" Rear Projection...
JVC AV-65WP55 65" Rear Projection HDTV-Ready Television Logo
152 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
