Question about Jandy Air Energy Heat Pump - 115,000 Btus - Chiller Model
Pool heater stopped heating and now won't work
At first it worked then it would kick off and we wouldn't have heat and now it won't come on at all.
    Top Expert:
  • Jandy Master
  • 8,177 Answers
Bad control board
Posted on May 25, 2016
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
  • 990 Answers
SOURCE: We have a Pentair 400 heater. First time to heat
You probally just need to increase your water flow. On the pipes going to the heater their should be a valve bridging the inlet and outlet pipes. This valve should be closed about 80-90% so it forces more water through the heater. I hope this helps.
Posted on Jan 02, 2010
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
  • 990 Answers
SOURCE: Pool Heater Mis-reading Temp.
Your temp sensors are on the heater, a small tube that slides into the water manifold, usually on the left side. On the remote it will be in one of the pipes coming from the pump or the filter. If it is after the heater you should move it to between the filter and heater. It will be a tube that is in the pipe with a stanless steel clamp holding it in place.
To find out wich one it is you will need to remove the remote from the system by takeing the wires that go to it from the wireing inside the heater and wire nuting the wires in the heater together. If the heater runs normal then it is the sensor for the remote if not it is the sensor for the heater. Let me know how you do and if need be we can get a little more specfic for your system. good luck.
Posted on Mar 29, 2010
SOURCE: LLD125 pool heater leaking water from inside
My heat exchanger was cracked. I found an old welder who knew how to weld the cracks for $100 vs $900 for a new exchanger,. Also ordered replacement seals for the 2 chambers. I used high temp automotive engine sealant as an additional sealant precaution. Also inspected tubes and cleaned corrosion. Works fine last 3 years. Takes some mechanical skills.
Posted on Jun 29, 2010
I am getting a Hi Limit 2 Fault message on my heater
overheating check gas pressure if too low will overheat if ok check manual bypass see if spring is bad also make sure filters are clean and pump is functioning ok
Sep 01, 2015 | Rheem M206A 206K BTU Pool and Spa Propane...
I have a Jacuzzi J340 Hot Tub. I am having trouble with the heating. When the pump is on, the water circulates just fine. once the heater kicks on, it runs for about 10 seconds, then clicks to OH, and...
make sure the heating element isnt touching the casing inside the heating tube. if its an indoor tub, make sure the filtration cycles are not set to constant. constant filter cycles on an indoor tub will generate residual heat from the circ pump running 24/7, causing tub to heat past 104 degrees
Sep 15, 2013 | Jacuzzi Pool & Spa
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
When i turn on my spa and heater it states on the outside unit "no air flow" and it won't heat up
that is usually an indicator of water flow not the air flow.
What does the hot tub do when you turn the breaker from off to on?
does it run through the purge cycle?
is it kicking out the GFCI?
if it is not tripping the GFCI then you most likely have either too little water flow for the heater to kick in or not enough water flow to activate the heater.
Try taking out your filter and see if that solves the issue.
you may also have a bad temp sensor if the tub just runs and runs but never heats up.
Rod
US Parts Center
888-521-6183
Feb 08, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Hayward HP error
check voltage coming in if ok check voltage after transformer if ok check safety circuit pressure switch voltage both leads if not replace or check for plugged copper line
May 04, 2012 | Hayward Heat - Pro 2100 Heat Pump Pool...
I have a haywood h series h 400 pool heater. Each night the the pool pump timer runs b/t 12-7am.. The heater was working fine. and pool temp is around 70-80.. However, lately the heater which is on when...
Allheaters run off of a thermostat just like the heat to your house. It will shut off once heated to the selected temperature. Turn up the temperature, and monitor it for a couple days.
Dec 28, 2010 | Hayward H-series Electronic Gas Pool...
We have a hot tub or jacuzzi inside or on the side of our pool. We had a new heater installed. The jacuzzi should heat up very quickly but now the pool tech claims the drain from the jacuzzi is blocked,...
Is the equipment to heat and filter the hot tub separate from the pool equipment or do both bodies of water share a common heater and filter pump? In most cases they share a pump and heater with valves that direct the flow of water depending on how the pool owner wants to use the pools.
The first thing you need to determine then is if the equipment is working properly. Is there flow of water to and from the spa? If so, is the heater burner kicking on? If it is running, is it running properly with sufficient gas pressure, 3-4" tall bright blue flames and stays on continuously during the heating cycle for the spa?
What is 'very quickly' for the time to heat the water? In other words, if everything appears to be operating normally but the water is not warming fast enough or at all how much time is elapsing before deciding the heater is not working?
How old is this equipment and how much experience do you have with this pool tech or the company they are from?
Nov 07, 2010 | Jacuzzi Pool & Spa
I have a AquaCal Heatwave H125C-A Pool Heater. The Heater is working in that the power is going on and the air is blowing- although- the air is usually colder than the outside air and now it is only air...
Sounds like your compressor is not running. After your fan goes on in one to five minutes you should hear the compressor kick in. If it does this and then kicks out again it can be something as simple as water flow and you can adjust the valves to get more or less flow to keep it running. If not you probally need a repairman. It is ether your compressor or the capicators that start the compressor and this is all high voltage. Good luck.
Jan 25, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
Jandy Air Energy Heat Pump - 115,000 Btus - Chiller Model Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
