Question about LG Televison & Video
PROBLEM WITH LG LCD TV RZ-15LA70 REV A
I HAVE AN LG RZ-15LA70 REV A, LCD TV. OVER HE PAST WHILE, WHEN YOU SWITCH IT ON, YOU GET A GREAT PICTURE FOR THE FIRST 15 MINUTES, THEN THE PICTURE GOES DARK, THOUGH YOU CAN STILL MAKE OUT WHAT IS ON, THE QUALITY ISN'THERE. IS THERE ANY WAY I CAN FIX THIS?
  • 192 Answers
SOURCE: LG Projection TV has dark picture
Normally the main cause of any DLP having a dark picture is the lamp. I would replace it and it should look like a new set again.
Posted on Jul 01, 2007
  • 58 Answers
SOURCE: Tv picture quality
You have a defective light engine. We just went through this and we have the same TV that you have. Hitachi knows about the problem but will play dumb when you first call. If you deal directly with their Customer Relations Department 800-654-7013, it will make a lot of difference than regular customer service.
Here's how they handled our situation. We called Hitachi after lots of research online and they gave us the names of some certified dealers in our area. The tech came out and in less than 1 minute said the TV had a defective light engine. We called Hitachi back and low and behold, they are aware of the problem...imagine that. Hitachi called the dealer directly and once the dealer confirmed the problem, they agreed to send a brand new light engine out to the dealer and the tech came out and replaced it. Here's the kicker...Hitachi will pay the for the part ($1500) but they ask you to pay for the install. Our install was $400. This was worth it to us being that we spent $3600 on this set 3 years ago. Once the light engine was replaced, the TV looked BRAND NEW! Please deal with their customer relations department at the number I lised above. If you deal with customer service, they will have you chasing your tail...so to speak! Good Luck! If you're willing to cover the install, the rest should go pretty smoothly..at least it did for us:)
Posted on Nov 25, 2007
SOURCE: No picture after 20 mins on LG LCD Tv
i have a 32" lg hd flat screen an it now does the same thing i got it on boxing day an its not even 5 months old
Posted on May 15, 2008
SOURCE: Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Posted on Jun 08, 2008
SOURCE: lg tv model rz-42px-11 fault....No picture
Your PCB boards have gone!
Posted on Aug 21, 2008
Hi, I have an LG RZ-20A70 TV and when i watch TV or play xbox the side are cut off the screen. (think its the picture ratio) any idea how to change this? as i have tried everything!
yes it is a picture ratio issue .
You need to look for the main menu tv setup button, its green on my lg remote .
Once you select this you should have an option to change screen ratio to 16.2 or wide screen if your tv supports wide screen .
Look for a little tv icon on screen and select that ,this should get you to pic set .
Jun 16, 2011 | LG RZ-20LA70 20 in. LCD Television
Sky TV REMOTE WILL NOT WORK MY LG tv RZ 37LZ55 ,NEED A CODE ....TRIED ALL CODES NON WORK !!
Hello Kenny
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
Cheers
Little Dish Fitter
Aug 29, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
No picture, no sound on a LG LCD tv
If it is hot were you live , That model of t.v doesn't like heat, anything about 35 degrees celsius could cause a problem with the card components.
Jul 27, 2009 | LG RZ-20LA70 20 in. LCD Television
PSU?
Look for any capacitors that my be puffed up or leaking. most of the time just replacing them fixes the problem.
Feb 20, 2009 | LG RZ-17LZ40 17 in. LCD Television
LG RZ-37LZ55 LCD TV no piture or sound. Set popped prior to probl
just repaired mine same problem
available on ebay ( lg power supply repair kit £17.99 does the job well
Jan 01, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
LG RZ 15LA70 User Manual
I contacted the shop I purchased the television from.
I sent an e-mail to LG requesting how to obtain a copy of the manual for RZ/15LA70 LG T.V. with no resonse.
My E-mail address is katecullinan2002@yahoo.co.uk
Jan 21, 2008 | Televison & Video
LG RZ-20LA70 How do you....
I'm trying to plug in a RZ-20LA70 TV into a Sony DVP NS29 DVD player? Which wires (red, blue, green) go into the coaxial, audio L, audio R, video slots? Thanks, Simon
Jan 14, 2008 | LG RZ-20LA70 20 in. LCD Television
Lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
Jan 01, 2008 | LG RZ-17LZ40 17 in. LCD Television
Televison & Video Logo
104 people viewed this question
Computer Repairing
Computer Repairing
