Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have installed my Intex Krystal Clear Saltwater system for my above ground pool and have run it for 12 hours. I want to run it another 12 hours. How do I start the system again instead of waiting on the timer to start it up?
  • 297 Answers
First of all you should not have set it to generat chlorine until straight filtering for 24 hours. unplug then plug it back in
88 will appear let your salt disolve by filtering only for the 24 hours then proceed to generate chlorine
It may look disolve but there are many hot spots that need to get distributed eveny
Posted on Jun 15, 2010
Intex Krystal clear saltwater system
I had nothing but trouble with that unit and it made its way to the dump minus the cord which I re-used as an extension cord,, I had a above ground 18 foot across and 4 foot deep and it never would make chlorine, which if your salt level is correct the machine does....
Mar 23, 2016 | Intex Automatic Salt Water System for ...
How many hours do you need to let the intex krystal clear salt water system run on an about 6000lb pool?
If you refering to 6000gals it needs to operate 4 hours in 66 degree weather, 5 hours in 82 degree weather, 6 hours in 97 degree weather, and 7 hours in anything than 97 degree weather.
Jul 22, 2011 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater System Model CS8110 service light is on. I have cleaned the unit inside and out, reset all power connections, and no luck. It runs about and hour and then the service light...
i need a part it is the electroytic cell .it got broken when we were winterising the pool last fall. we are both handicapped and on ss and use the pool to help with the arthris and soreness in our backs .if there is any way you can help we would greatly appericate it .
thank you elbert boswell and wife judy boswell
Jun 25, 2011 | Intex Automatic Salt Water System for ...
I don't know hw to assemble the pump and accessories. i need inst
The pump is assembled as this photo shows. This is my pool. I have an owners manual so if you list the size of your pool I can provide information on amount of salt required and hours of operation each day. 8e665e2.jpg
May 30, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
469 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
