I need the programing code for a sylvania tv
Give these a try.
SYLVANIA ..........0062 0004 0009 0135
......................0189 0183 1141 0227 0456
......................0008 0068 0075 0141 0161
Or these:
Sylvania
004, 006, 008, 019, 062, 068, 069, 074, 075, 076, 077, 088, 116, 161, 183, 184
And incase you need the programming instructions, here ya go!
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed, try the Code
Search method described below.
Thank you for responding that gives me something to work with.
