Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
How to find D6116 & D6301
Looking to find part D6116 and D6301 on the G board. What Iam seeing is a D with a mark through the middle of it or its a B. Would be a little black square on top of the solder and D6301 looks like a diode with two legs going through the board.
  • jd0109 Apr 10, 2008
    I meant D6116 looks like a little black square on top of the solder.
  • 298 Answers
You can find those parts for your model in the links below.
Sony KP-57WS520 D6116 Replacement Part
Sony KP-57WS520 D6301 Replacement Part
Posted on Apr 10, 2008
Red lite blinks tv will not power up. Sony kdp-51ws655
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero detect circuit failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they repair it and return it). A new board costs about $80 on eBay without having to send them your (core) bad board. Sometimes they are not available and you must send your board in for repair. this is MUCH less expensive than SEARS, which charges several hundred dollars.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D6116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of the "G" board. Unplug the TV set, leave it for 10 hours (to discharge the capacitors). Remove the brown back, carefully unplug the cables, unscrew the two mount screws, and unclip the front retaining tab.
This is the MOST LIKELY failed component, D6301. It is a diode and MUST be unsoldered and replaced. Make sure you know that diodes have a SPECIFIC way they must be installed. Note where the stripe is on the component. You can locate a "good" diode by searching on eBay for "sony a1054157a". You should see a parts kit for about $25, give or take.
One other possible culprit is the D6116 diode. This is a surface mounted component (SMT) and will require a steady hand and a very fine-tipped solder iron. I would replace the D6301 FIRST and re-connect the "G" Board to see if that is the ONLY culprit. If you STILL have the same problem, then replace D6116.
Oct 02, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Standby/light flashes 9 times, what does this means.
call pts electronics replace power board in you tv dont try to fix just replace board
Aug 10, 2010 | Sony KP-51WS520 51" Rear Projection...
Problem with sony kp-57ws520 57in.rear projection t.v. need to know rating or part number for d6301,d6116
D6301 p# 6-500-567-21 desc 10ERB20-TB5. D6116 p# 8-719-081-97 desc MMDL9145T1. Hope this helps.
Nov 20, 2009 | Audio Players & Recorders
My sony Wega KP-57WS520 TV blinks 9 times and the picture and sound won't come on.
the blinking is an error code telling you that tv needs a new power supply.. have your tv serviced...
Nov 17, 2009 | Sony KP-57WS520 57" Rear Projection...
No picture or sounds red light blinks 10 times
The parts you need are two diodes, D6301, D6309, and D6116, Sony part numbers 6-500-567-21 (D6301 and 09) and 8-719-081-97 (D6116), they are located on the G board, and that's located on the left side of the set, as seen from the back.
D6116 is connected to pin 9 of transformer T6101, and D6301 and 09 are in series off of pin 7 of that transformer.
May 05, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
KP-57WS520 9 LED blinks
Don't replace the entire G board! that is expensive! The diodes are available from MCM electronics and can be easily replaced.
Aug 18, 2008 | Sony KP-57WS520 57" Rear Projection...
Stand-by light flashing, but TV will not turn on.
try this
Resolder D6116 & D6117 (Surface Mount) REPLACE D6301 (Do not just resolder D6301 REPLACE IT) Can use ECG116 (1N4004) ALL On G Board
Jul 05, 2008 | Sony KP-57WS520 57" Rear Projection...
Re: Blinking Stand-By Light
This is the fix and it is not likely a do it yourself
Apr 22, 2008 | Sony KP-57WS520 57" Rear Projection...
Sony rear projection tv How to de-solder
I would suggest not to desolder that transformer until you are certain that is defective.
Try to change D6116 and D6301 first.
You can try Radio Shack or check this site.
Good Luck.
Apr 10, 2008 | Sony KP-57WS520 57" Rear Projection...
Audio no video
You have whats called a zero crossing detector problem my friend. Usually the problem is D6116 and or D6301 0n the G board.
Jun 09, 2007 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
3,856 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
