Question about Frigidaire FAP094P1Z Portable Air Conditioner
Red bucket full light stays on.
The light is on, but no water is draining. Only the power on/off and fan setting work.
  • 420 Answers
If the bucket is full then the pump should be running, if the pump is not running it is a faulty pump motor, a faulty control board, a faulty level switch for the pump motor or the water level alarm float switch.
Posted on Jun 07, 2010
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
Dehumidifier stopped working because "water bucket full" indicator light stays on, although there is no water in bucket.
In the water bucket is a float assm. scale forms on the assm. and causes it to stick. Remove the float assm. and carefully remove the scale. Should start working again once done. If not you may have to replace it.
Mar 11, 2013 | Dehumidifiers
Keeps flashing bucket full and there is no water in the bucket.
water is not draining into the reservoir an thats why it keeps on blinking so clean out the drain assembly an treat with bleach ,,,,
May 24, 2010 | LG DH504E GoldStar Dehumidifier
Red light on??
that means the internal tank is full and needs to be emptied. Drain useing a bucket or the hose that came with the system. Open up drain caps and just drain it. Top and bottom caps.
Jul 16, 2009 | Danby DPAC120061 Portable Air Conditioner
Power lose
I have a 45 pint. I have to slide the bucket in and out of the unit multiple times. Make sure to wait a few seconds after each time to see if it will recognize no water (sometimes the red light comes on, but then changes it mind). Also, I've found that leaving the bucket a little crooked will make it respond. It sucks, I know. Mine is only a year old too. Should not be a problem like this!
Sep 14, 2007 | Frigidaire FDL45P1 Dehumidifier
Red light wont shut off
check to make sure your fill bucket is correctly placed back into the unit. there is a safely switch that will not let the unit work without the bucket in place..hope this helps let me know?
Aug 24, 2007 | Danby DPAC10031 Air Conditioner
Frigidaire FAP094P1Z Portable Air Conditioner Logo
300 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
