Question about Maytag EPICz Electric Dryer
I can't clear out the F24 error message. What should I do?
  • 5,911 Answers
"F24" is a Temperature sensor (NTC) error. The following link explains how to troubleshoot this problem:
http://www.fixya.com/support/r3608650-f24_error_code
The NTC, or temperature sensor, is located under the bottom front of the wash tub. It is a small square black plug between the heating element terminals. In many cases the connector plug comes loose and simply needs to be reconnected.
If the NTC is defective, a replacement can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites have helpful exploded view diagrams that you can use for reference to locate and correctly identify the parts you need. The average cost is about $10. The NTC and Heating Element is usually listed under the "Tub and Motor Parts" parts listing.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
If you have any questions about this repair, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on Jun 07, 2010
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
F-24 flashing on Kenmore He washing machine.
F24 error on an ASKO is something to do with the water temperature sensor. Apparently the Asko is the same a s a Kenmore?? Look up ASKO F24 error on "Google" there is a bit more info.
Dec 27, 2014 | Kenmore Washing Machines
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
When i try to wash a laod of clothes it keeps putting up a f24 and wont do anything
Hi
Error F24 means water temperature sensor error. If the sensor reading is not within range then this error comes up. Check whether the sensor is not disconnected, if it is then connect it and check if the error is still there. If error doesn't go then you'll need to replace the temperature sensor.
Please check part#24, temperature sensor in the diagram--
Please post back for any further assistance.
Daniel
Aug 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hello, I'm getting and Error Code F24, does anyone
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. The part number is 8181705. Refer to the parts illustrations under the "Tub and Basket Parts" heading for item 26 as a pictoral reference to assist you in locating the sensor on your washer.
If you have any questions, please let me know. I hope this helps you.
Dec 08, 2009 | Maytag EPIC MFW9700S Front Load Washer
I keep getting the message f24
"F24" is a temperature sensor error. The following link explains how to troubleshoot and repair:
In some cases, this is just a simple matter of a loose connector on the sensor. However, if you require parts, the following web sites are great sources to use:
repairclinic.com
The part number for a replacement sensor (if required) for the model number you have this question listed under is 8181705. The average price is about $10. Prices vary between these sites, so shop around for the best deal.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
F24 error code
Take off the lower panel of your washer and under this panel on the back of panel is a book which tells you what the error codes are and how to fix them or test for them. It looks like a tempature sensor code to me.
Apr 19, 2008 | Kenmore 46462 Front Load Washer
Maytag EPICz Electric Dryer Logo
352 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
