Question about Microsoft Windows Server 2003 Standard Edition with SP1 for PC
Installation active directory - Microsoft Windows Server 2003 Standard Edition with SP1 for PC
    Sniper:
  • 135 Answers
Hi,Nice post,for my website's domain setup is very easily with this http://www.tucktail.com/ site ,this site provide very best service for hosting and domain at very very cheap rate ,visit this site for more details.All the best.
Posted on Jun 19, 2010
    Problem Solver:
  • 7 Answers
The installation is a lengthy process.Involves many steps.Go through the provided link, this contains all the required information.http://www.petri.co.il/how_to_install_active_directory_on_windows_2003.htm
You can also go for a third party software that will take care of all the proceedings.like: http://www.manageactivedirectory.com/
Besides this, you will also need to install the admin pack separably depending upon the OS you are using.
Posted on Oct 10, 2011
  • 428 Answers
That's a pretty long topic though.
If you want to install AD in your machine.
Here are the requirements.
  1. You must have configured the network properly. You must have network connection present. You must have TCP /IP addressed assigned properly to your router (+ switch if you have) and the machine.
  2. You must issue a static IP for the Server (if you use DHCP add the IP range with an exception).
  3. You must have configured DNS properly and its a must. Or you can install DNS automatically while you install AD but not recommended. DNS is vital.
  4. Wins is optional - Only if you use legacy Operating Systems.
How to setup a proper DNS ?
  • Go to Control Panel.
  • Add Remove Programs -> Add Remove Windows Components.
  • Double Click on Networking Services.
  • Check ONLY ON DNS in the next panel.
  • Then it will be installed.
  • Check the settings using this command using a command prompt.
  • type nslookup and hit enter. It will show like No default servers, time out etc. Don't worry about that. Just after you type nslookup you will be then in the utility (this prompt is the one you are going to have. >
  • Type in www.google.com as an example. If it resolves the IP address for the Domain Name then its installed properly.
Configuring DNS.
  • Go to Programs -> administrative Tools. -> DNS
  • The DNS management windows will be opened for you.
  • Its the time to configure some options and create a Forward Lookup Zone and a Reverse Lookup Zone (only if you are planning to debug).
  • Right click the Forward Lookup Zone folder and Select "New Zone"
  • Select "Primary" (Note: The check box will not be available to select which enables the DNS to be stored in AD. You have to do that after the installation of AD).
  • Next is the "Zone Name". Its Vital. As an example if you plan to give your domain fixya.com you must give the same name as the DNS domain name/zone name. (Note: You can use yourdomain.local as well if you plan to keep it local. It easy. The "yourdomain" is the name which you are going to give).
  • Then "Replication and Update Settings". Use "Allow non secure and secure" if and only if you are limited to an internal network and it gives less errors and less configuration effort.
  • If you want to debug its better to use a "Reverse Lookup Zone". It does the alternate thing which means converting IP Addresses to DNS names. Similar to this you can set that up. When the address is requested use the network address/subnet.
  • Then Stop and Restart the DNS. Check whether your Server is listed in the DNS after expanding Zones.
  • If you plan to use a separate DNS that's just fine. But your other machine must point to the DNS (in its TCP/IP configurations) and you have to add the machine to DNS FLZ (Forward Lookup Zone)
  • By clicking a PTR adding option while adding a machine to DNS FLZ a Ponter record automatically gets create in the RLZ (Reverse)
  • There is a dedicated DNS Event Viewer built in and you can check for errors.
  • Additional...
  • Configuring Forwarders.
  • Right click the DNS Server object for your server in the left pane of the console, and click Properties.
  • Enter the IP address of the DNS servers you want to forward queries to. Typically this is your ISP's DNS Address.
  • Then Click OK and finish it.
Now back to AD installation.
  • Right click on My Computer icon.
  • Go to properties.
  • Go to Computer name.
  • Click on change and examine if the name suites properly.
  • If so Click on "Change".
  • Type the Primary DNS suffix (your domain name suffix as an example fixya.com). This is a very important step. Most of the Admins complain that they have experienced failures without configuring this properly.
  • You don't need to select the check box if any their.
Check TCP IP settings again.
Now to run dcpromo. This is the Domain Controller Promotion command. Get "Run" box in Start menu and type dcpromo and hit enter. Then the process will begin. After the completion of providing the required information as follows, it will run a check to ensure all the settings work well. Look at the DNS diagnosis as well. This way I m sure that will not fail since you have added the suffix.
Then after some time you will be asked several settings.
  • Press Next after the process.
  • Choose "A Domain Controller for a New Domain" and Click Next.
  • "Create a new Domain in a new forest" and click Next. (Note: Only if you are promoting this as a Root of a New Forest;Not a Child).
  • Enter the Name for the Domain. Must be the same as the DNS Name.
  • Click Next and then Accept the Netbios Domain Name and the Database and Log file location. If you plan to Secure Logs then you have to provide an "Alternate Place" (Volume).
  • Accept the "Sysvol" location. Don't change this if and only if you have any performance issues on your mind. Click Next.
  • Then the DNS will be analyzed. If the result Succeeded you can go forward. Please examine it whether it was successful or not. If its unsuccessful you have to re run the process. Check the "Event Viewer" as well.
  • If it succeeded...
  • Click Next several time and you will be directed to a window which asks the "Compatibility Mode"
  • Check "Compatible only with Windows 2000 or Windows Server 2003" if and only if you do not plan to run Legacy Applications on Obsolete versions.
  • Enter the "Restore Mode Password". This must be different from the Administrative Password. Note: You can change this anytime using the NTDSUTIL utility.
  • Click Next again several times and then if all went well you will be served with the "Finish" button.
  • After the Installation you must Reboot the machine.
  • Then Log in with your Credentials and Check whether the "Active Directory Users And Computers", "Active Directory Sites And Services" etc available.
  • If you can see that the users, groups and all the containers available then its successful. Examine each location. Check the SRV Records as well.
  • Then Open the DNS console. Expand the FLZ and check whether there are four SRV record folders. Otherwise something must have gone wrong with the DNS. You can examine using the Events as well.
  • This may occur if you have selected the "Allow only Secure updates" option. Make them Dynamic and check if any failure occurred. Right click the zone, and then click Properties. On the General tab, under Dynamic Update, Select "Nonsecure and secure".
  • Then Stop and Restart the Netlogon Service. You can use command prompt and type net stop netlogon and entering. Then net start netlogon and hit enter.
  • If everything function well and all the SRV records present you have to Add the DNS server to the AD. And then you will be able to allow "Secure Only" Updates.
  • This type of zone is known as an Authoritative Primary Zone. Zone data of an Active Directory Integrated Zone is replicated during the Active Directory replication process. Active Directory Integrated Zones also enjoy the security features of Active Directory.
  • To do so:
  • Expand the "Forward Lookup Zones" and Select the Domain Name.
  • Right click and Select Properties.
  • Under the "Type" Click "Change".
Posted on Jun 08, 2010
  • Tharinda
    Tharinda Jun 08, 2010
    If you face any erroneous situation please feel free to contact me. Works as an AD Expert for several years.
    Now you are ready to begin your work.
    Thanks for contacting Fixya! Hope this solution will help you to solve the issue. If so please be kind enough to Rate the Answer with a Testimonial.
I have an problem with getting my ADSI Frames to work with Win 7 x64 in Hyena 8.1!
Hey this is an easy one, search Google for Active Directory Remote Management software.
This is a free .msi package that installs the ADSI hooks so Hyena can hit your active directory server.
Hope this helps.
Mar 01, 2011 | Microsoft Windows 7 Ultimate for PC
I have installed via disk, the FSX missions airbus A321 Luft. I activated the program via the exe and installed it in the correct directory. However the missions do not appear in my Microsoft flight...
Try reinstalling it but let it go to the default directory. FSX doesn't find programs where you place files in a non-default directory. Good luck and happy flying!
Jun 29, 2010 | Microsoft Flight Simulator X for Windows
How we can remove active directory in windows 2003 safe mode ?
hello,
you just try to remove as force.
go to run, after this type " dcpromo /forceremoval ".
it will do this for you, if any issue on active directory or ad database.
you can do this command in normal or safe mode.
thanks,
Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
Cannot Open DSA.MSC file error
When you install the Administration Tools Pack on a computer that is running Windows XP Professional x64 Edition, the Active Directory Users and Computers MMC snap-in file (Dsa.msc) is installed in the %windir%\Syswow64 folder. Additionally, the computer's file system maps the Active Directory Users and Computers MMC snap-in to the following path: DriveLetter:\%windir%\Syswow64\Dsa.mscHowever, the Active Directory Domains and Trust MMC snap-in incorrectly specifies the path of the Active Directory Users and Computers MMC snap-in as follows: DriveLetter:\%windir%\System32\Dsa.mscWhen the computer's file system tries to locate the Dsa.msc file from within the Active Directory Domains and Trust MMC snap-in, Mmc.exe is run. Mmc.exe is run because the Dsa.msc file is associated with Mmc.exe. When Mmc.exe is run, it uses the following path to locate Dsa.msc: DriveLetter:\%windir%\System32\Dsa.msc DomainPathAfter the Mmc.exe command is run, the Active Directory Domains and Trust MMC snap-in tries to locate the Dsa.msc file. Because the Dsa.msc file does not exist in the %windir%\System32 folder, the error message that is mentioned in the "Symptoms" section is generated.
To resolve this problem, manually copy the Dsa.msc file from the %windir%\Syswow64 folder to the %windir%\System32 folder.
Your hardware manufacturer provides technical support and assistance for Microsoft Windows x64 editions. Your hardware manufacturer provides support because a Windows x64 edition was included with your hardware. Your hardware manufacturer might have customized the Windows x64 edition installation with unique components. Unique components might include specific device drivers or might include optional settings to maximize the performance of the hardware. Microsoft will provide reasonable-effort assistance if you need technical help with your Windows x64 edition. However, you might have to contact your manufacturer directly. Your manufacturer is best qualified to support the software that your manufacturer installed on the hardware.
For product information about Microsoft Windows XP Professional x64 Edition, visit the following Microsoft Web site:
http://www.microsoft.com/windowsxp/64bit/default.mspx (http://www.microsoft.com/windowsxp/64bit/default.mspx) For product information about Microsoft Windows Server 2003 x64 editions, visit the following Microsoft Web site:http://www.microsoft.com/windowsserver2003/64bit/x64/editions.mspx
May 30, 2009 | Microsoft Windows Server Standard 2003 for...
Active directory is rebuilding
if u edit settings in active directory and editing the rools
bake up your setting
and remove active directory
them stup it agien
Nov 06, 2008 | Microsoft Windows Server Standard 2003 for...
Active directory
hello,
we have a following command option to open active directory:
dsa.msc
thanks,
Sep 30, 2008 | Microsoft Office Outlook 2003 for PC
2003 server
Hey deepak,
Yes, you can change password in 2003 server without any cd.
The thing that manages all the information about Passwords, User Accounts, Printers, And providing permission to all clients that are present on ur network, is "Active Direcory Service"
You must install Active directory to use it's funtionality.
to install active directory-
Go to start -> Run
then type "dcpromo"
Follow the wizard as per your network domain description and requirements.
Restart your computer.
Go to start -> Administrative tools -> and select Active directory users and computers.
In Active directory user and computer snap-in
Expand ur server and click Users.
You will be now able to see different accounts available on ur computer.
Select and right click Administrator and select change password or create password.
Type your password with including any of the capital letter and an digit like "Password01" check and uncheck different parameters given.
(give me ur acknowledgement by rating me)
Romy
Aug 02, 2008 | Microsoft Windows Server Standard 2003 for...
DNS
DNS is the primary name resolution service for Windows Server 2003. Active Directory depends on DNS for domain controller location, and DNS influences Active Directory domain naming. Thus, to fully understand Active Directory, it helps to understand how DNS acts as an integral component in the design of Active Directory.
DNS provides Active Directory with both a name resolution service for domain controller location and a hierarchical design that Active Directory leverages to provide a naming convention that can reflect organizational structure.
Typically, a DNS domain namespace deployed to accommodate the Active Directory mirrors the Active Directory domain namespace. In cases where there is an existing DNS namespace prior to Active Directory deployment, the DNS namespace is typically partitioned for Active Directory, and a DNS subdomain and delegation for the Active Directory forest root is created. Additional DNS domain names are then added for each Active Directory child domain.
DNS data is used to support the location of Active Directory domain controllers also. During or after the creation of the DNS zones used to support Active Directory domains, the zones are populated with DNS resource records that enable network hosts and services to locate Active Directory domain controllers.
PS: As sourced from Microsoft Technet Site
Jul 24, 2008 | Microsoft Windows Server Standard 2003 for...
Features of active directory
Active Directory think of it has management system for all network LAN PCs in your domain. You can add users to certain enterprise groups, you can disable accounts, push and pull software application better then you can in SMS domain. I use to to clone user accounts or create new user groups. Very easy to learn. To install on Server requires a domain, DNS. If you're using Windows Server 2003 and setup the server to manage active directory all the options for the installation process will appear for installation. There are a lot of info online and in books if you need more info. There are training classing offer at MS Solutions Centers.
Jul 23, 2008 | Microsoft Windows Server Standard 2003 for...
Regarding ActiveDirectory Services in Windows system
Active Directory (AD) is a technology created by Microsoft that provides a variety of network services, including: using the same database, for use primarily in Windows environments. Active Directory also allows administrators to assign policies, deploy software, and apply critical updates to an organization. Active Directory stores information and settings in a central database. Active Directory networks can vary from a small installation with a few hundred objects, to a large installation with millions of objects (though not easily [3]).
Active Directory was previewed in 1996, released first with Windows 2000 Server edition, and revised to extend functionality and improve administration in Windows Server 2003. Additional improvements were made in both Windows Server 2003 R2 and Windows Server 2008.
Active Directory was called NTDS (NT Directory Service) in older Microsoft documents. This name can still be seen in some AD binaries.
There is a common misconception that Active Directory provides software distribution. Software distribution is run by a separate service that uses additional proprietary schema attributes that work in conjunction with the LDAP protocol. Active Directory does not automate software distribution, but provides a mechanism by which other services can provide software distribution.
Jul 01, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server 2003 Standard Edition with SP1 for PC Logo
248 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
