Question about Definitive SubAmp 600 Amplifier
Placement of definitive supercube 2
I have klipsch reference speakers in 7.1 system, I have a pioneer 92 txh, currently i have been experimenting with sub placement. I have tried the trick where you put sub in listening position and walk around room and i didnt find good results my gut tells me to put in corner I have tried 4' inches from back and side and found pretty good results. I think i will put it 3" inches from back and side. My gain control is in the third notch position because if it is any higher the pionner doesnt accept it in calibration. i think im on right path. does anybody have any insight for me?
  • 54 Answers
Make shure your crossover on the amp is set at 80hz. If closer to side walls you will get more response but may be muddy. Make sure it goes low enough to comliment the klipchs.
GOOD LUCK
BIGRED
Posted on Apr 11, 2008
Where to buy replacment speakers
This is a specialty speaker so I do not recommend looking anywhere but with definitive for this. Their products are like high performance sport car assessories, where they are "tuned" to work as a cohesive system. If you really don't want to go that route, start with partsexpress.com.
May 18, 2014 | Definitive Technology SuperCube Reference...
I have a Pioneer VSX 823 - K, and when I hook up my Klipsch HG-12 300 watt subwoofer to it, the receiver is prone to overheating or just shutting off with too much bass. Is there a fix to this?
This is receiver thermal going in protect issue and has no bearing to your sub, The sub has its own power amp and not supplied by the receiver. Thermal module may be bad. See a tech.
Mar 06, 2014 | Pioneer VSX-823-K
Is a Denon most compatible with new Klipsch KB-15 speakers
no brand of receiver is matched to certain speakers. Denon is a decent brand of receiver (but most of the low to mid range models are almost identical to Pioneer inside). Go with a good receiver that has the functions that you need that fits in your budget.
Dec 05, 2013 | Sherwood RX-4105 Receiver
Zone 2 Amplifier Need
Reread the detailed answer provided in response to your earlier post on this issue
Jun 10, 2013 | Pioneer VSX1020K Receiver
Pioneer VSX 1020K - Zone 2 Setup
I referred to a similar zone 2 arrangement for a Yamaha receiver. It shows a separate amplifier and notes that only analog signals are sent to zone 2. The analog output from a source must be connected to the analog input on your Pioneer unit for zone 2 to work. Your outdoor music environment will be limited to left and right front speakers and...alas...no surround
Jun 03, 2013 | Pioneer VSX1020K Receiver
My subwwofer does not seem t power on .....it is also not picking up a signal...... can you help with this
Hi slikrik
Please check your external connections, power if everything is ok then.. First please confirm when did you purchased this Active sub., This sub system is having 5years warrantee on Speaker and 3year on Amplifier. Hence, if you are the due date please give it for free checkup and replacement for parts.
-sai kumar
Dec 28, 2010 | Definitive SuperCube II 8" 1250-Watt...
My Definitive Technology Supercube ii subwoofer is not powering on. I've checked the electrical outlet so it's not that. I suspect it might be a problem with my subwoofer cable but I don't want to take...
Unfortunately, the most common problem with powered sub woofers, including definitive technology, is that the capacitors inside dry out. To check the speaker, you can connect any line level audio source (like an mp3 player) to the speaker and see if it comes on. If it does come on, then you will know the speaker is ok. If not, then the speaker will need servicing. Powered sub woofers are not usually a DIY project.
Dec 11, 2017 | Definitive SuperCube Reference Subwoofer...
Pioneer VSX-01 TXH receiver turns off
Sounds like the speaker circuit is overloading or the receiver is overheating.
Check to make sure all speakers are in phase. Pos to Pos. Neg to Neg.
Make sure receiver has plenty of cooling room.
Hope this helps.
Apr 16, 2010 | Pioneer Elite® VSX-01TXH 7.1 Channels...
I have a bose v20 and a harmon kardon receiver. Should I be returning the bose system, buy just the speakers, and and outside subwoofer, or what is the best system for watching movies etc? What would be...
If you have the harmon kardon receiver, check out this reasonably priced system. You can actually find it cheaper than at this website but I have these speakers and, when paired with the Klipsch sub-woofer, it makes movie watching an unbelievable experience.
http://www.klipsch.com/na-en/products/quintet-sl-home-theater-system-overview/
Good Luck!
Oct 19, 2009 | Bose 901 VI Main / Stereo Speaker
How to hook up speakers to emachine t3638? i have the klipsch 5.1 set
The EMachines T3638 comes with High Definition Audio support and you should be able to connect a 6 speaker system (1 subwoofer and 5 speakers).
I believe they are color coded as well. I believe the speaker set you are referring to is the Klipsch ProMedia Ultra 5.1. Is that correct?
Below is the a link to the connection instruction manual. It is a pdf document that you can print out. The instructions for installing the Speaker set is on pages 3 & 4 under Signal Connection and Speak Connection.
http://www.klipsch.com/media/products/owners-manuals/ULTRA51MANUAL_ENGLISH.pdf
It should be pretty straight forward, but send me a note if you have any questions about the process.
MO
Jul 13, 2008 | Computers & Internet
145 people viewed this question
Top Definitive Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob
Rob
Are you a Definitive Audio Player and Recorder Expert? Answer questions, earn points and help others
