Question about Troy-Bilt Pony Garden Tiller
Throttle /kill switch linkage problem
I have a troy-bilt pony model 130292 type 1139-01 code 82020107 5 HP tiller I'm having trouble reconecting the throttle linkige and the kill switch. It runs strong but at full throttle. I would like to locate a shop manuel for this tiller any help or suggestions would be greatly appreciated
  • 112 Answers
SOURCE: i'm trying to find an operating and parts manual
go here http://troybilt.manuals-website.com/cgi-bin/pony_manuals.pl
Posted on Jul 15, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
  • 135 Answers
SOURCE: Troy-Bilt Pony Tiller runs terrible with blue smoke
When you say there is an oil fill on both sides of the tiller. If you are referring to the engine, then yes it does have two oil holes one on each side that requires the use of Briggs & Stratton SAE 30 oil. If you have filled this up until it's ready to overflow, then you have put too much oil in there. It should only be filled to the mark on the dip stick and no higher. If you did put more in to bring it up above the mark, then that would explain the reason for the blue and white smoke. It's trying to run and give you the power and you have given it too much oil to handle and therefore, causes the sump to dump the rest of the oil up the vent tube to the carburetor and in turn it will **** it back in and try to burn it. Hence, the fouling on the plugs. If this is not the case then you have an issue with piston rings or maybe even the cylinder walls. This motor has 3 rings. The top ring and the second ring are compression rings which aid in easier starts. The last ring is the oil ring which keeps oil from getting pass the other two rings. If that ring is worn you'll have to have a complete new set replaced. Also, if you find this to be true, have a dealer check your cylinder for possible out of round. Hope this doesn't scare you. But with all my years fixing these things, most of the problem is related to the customer and their lack of knowledge about the units.
Now if your referring to the gear box which you may be referring to as a transmission. This unit does not take trans fluid. This unit requires a special lube, more like a gear lube. Contact your nearest Briggs dealer and he will be able to inform you exactly as to what you need. Or contact Troy Bilt dealer, that'll even be better.
Good luck. Hope this clearify things for you.
Wayne
Posted on Oct 03, 2009
Testimonial: "Thank you very much"
al_kupchella
  • 843 Answers
SOURCE: broken pull cord on my manual start Troy-bilt Pony
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Posted on Jun 15, 2010
jyackle5
  • 8197 Answers
SOURCE: looking for manuel for pony
You can get the manual on the link below.
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/tillers/769-03556.pdf
Posted on Feb 20, 2011
Need gasket carbereter kit
I have been trying to help you. It appears that the "pony" model has submodels as well I will send you this link and please post back with which model is yours. Model numbers are the BIGGEST help I get, because I can research this machine all day and not have the correct carburetor for your exact model. Here are the current Troy Bilt "Pony" Tillers for sale on the net.
http://www.bing.com/shopping/search?q=Troy+Bilt+Pony+Tiller&FORM=HURE
Again, please reply. I will get your reply and continue to assist you. Thanks!
Jul 04, 2011 | Troy-Bilt Pony Garden Tiller
I WAS JUST GIVEN A TROY BILT 5 HP REAR TINE PONY ROTA TILLER. THE DECAL WITH THE MODEL NUMBER ETC. ON THE TINE CASING IS UNREADABLE. DO YOU HAVE ANY IDEA WHAT MODEL THIS MIGHT BE? I WOULD LIKE TO GET A...
The serial # of the tiller should be stamped directly above the right wheel on the transmission housing. This should give you more info to work from.
May 02, 2011 | Troy-Bilt Pony Garden Tiller
Pony size Troy-Bilt 30 years old\r\nQuestion; Can motor be replaced?
Yes but unless you purchase a engine with the two shafts, one for forward and one for reverse, you will lose your reverse. If you don't mind not having a reverse just go to a nearby Harbor Freight store or order on line a Greyhound 6.5 HP engine. these are Honda clones and run great they just had a sale here in Columbia Mo. and it was on sale for $99.99. I have used these on many of the Troy Bilt Horse tillers and they work great. They have metric threads and you may not be able to use your throttle cable but for the price you can't beat it.
Frank
Oct 03, 2010 | Troy-Bilt Pony Garden Tiller
I need a free owners manual for a troy bilt pony rototiller model number 12211
http://manuals.mtdproducts.com/mtd/Public.do
Go to the above website and type in 12211 for your model number and 1 for your serial number. You will be able to download a free copy.
Frank
May 20, 2010 | Troy-Bilt Pony Garden Tiller
Need belt diagram for Troy bilt Pony. The drive belt just broke and I need to 1, buy one and 2, replace.
hi im having trouble on my troy belt riding mower it is a 42 inch im tring to change the belt we have it on but it not right please help me
May 15, 2010 | Troy-Bilt Pony Garden Tiller
Won't start no fire
If you are not getting fire to the plug you first disconnect the kill wire then check for fire again. If you still have on fire replace the coil, if you do get fire check the switch then the wire for a short.
Jul 12, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
148 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
