Question about Amana Refrigerators
Hi, Bottom freezer still working. THe vegetable bins in upper part seem to be working also. The rest of the refrigerator is 60 degrees! This happened last Friday.thanks for any help.
    Genius:
  • 1,040 Answers
Dear Cmonteiro,
Your fridge requires servicing.... there is a hardware problem......
Posted on Jun 07, 2010
Refrigerator thermastat set to 37 degrees but registers at 28. Freezer set at 0 degrees but registers at -2. Frig/freezer do not feel that cold but vegetable bin (produce bin) in refrigerator is...
i have never seen the problem
my idea is the thermostat is bad. but won,t both of them be bad.
you try to check the damper motor swithch and damper motor
good luck
Jan 12, 2011 | Frigidaire FRS26R4A Side by Side...
GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Jul 11, 2010 | GE Refrigerators
Fridge portion seems warm 60 degrees at lowest setting
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water in bottom of "fridge" and in vegetable bins
Hi: I'll assume this is should be a frost free freezer. If so the defrost drain is clogged and the water isn't getting to the evaporator pan. Without knowing the specifics although it sounds like a top freezer. Look for a drain below the evaporator coils. The will be in the back of the freezer behind a panel. Some models have a drain hose behind the ref. Use a strong solution of clorox and water to clean it out. The parts list or diagram of the fridge will help you find the drain. If you don't have it enter your model no. at sears.com parts direct. I hope this helps, Jeff
Jun 02, 2009 | Refrigerators
Refrigerator compartment freezing
Experience tells me the design should maintain 40 -34 degrees in the refrigerator section when the freezer is between 0 and -10 You might check this if you have a thermometer for the job, and adjust the thermostat accordingly. Your unit may also have an airflow control (I didn't research) to adjust the refrigerator independent of the freezer.
May 25, 2009 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Mar 26, 2009 | Kenmore 53342 / 53344 Side by Side...
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool EL7ATRR Refrigerator
Too cold in vegetable bins
Air flow ports adjusted correctly? Air flow fan running? I once had a bad temp sensor on the freezer coil that would not let the fan run.
May 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
19 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
