Question about Dell Inspiron 5160 Notebook
My dell inspiron will not boot up completely. When turning it on its starts normal and then with the bar is about 3/4 over it starts over again.
This is no Windows problem. The problem is the power connector on the motherboard. You can bypass this problem by connecting the AC adapter and hold down the connector during POST (boot-up process). I experience the same problem and haven't found any other solution this far
Posted on Jun 11, 2010
    Novelist:
  • 166 Answers
You must install Windows again - or try Tapping F8 on Boot-up to go into Safe-Mode which will leave a lot of the drivers out.  Then you may go into the System and see which hard-ware is conflicting.
If this doesn't work, upon reboot, go to CMOS (usually F1, F2, or Delete) Gets to the STart-Up or CMOS and select the Boot Sequence to Select start-up on CD-Rom.
Place your OS (XP or ??) in drive and reboot.  Tap F12 to bring boot menu up and select CD-Rom.
Try fixing windows before a new installation.
Have a product key on hand for fresh installation of OS (operating System - eg, XP, Win7...)
I recommend a second Windows directory to have a back-up of the drivers for motherboard etc, to retrieve from once the second OS is installed otherwise you won't be able to get onto the internet or anything as all motherboard drivers will be missing!
You can delete the original directory later but is a registry edit and one must be very careful here!
This is complicated but should take care of your problem.
Hope you can figure it out by my description.
East Coast Canada!
Good Luck!
Posted on Jun 08, 2010
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
When i try to reboot my dell inspiron 1501 to factory settings after i press F8 and click "repair computer" it just starts normally and goes to my desktop.
To restore your Dell computer to it's original factory settings, here's how:
To use PC Restore:
  1. Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
  1. Immediately upon seeing the blue bar, press .
If you do not press in time, let the computer finish starting, and then restart the computer again.
notice.gif NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
  1. On the next screen that appears, click Restore.
  2. On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
  1. When prompted, click Finish to reboot the computer.
note.gif NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
  1. When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the computer was turned on.
  1. Click Next.
The System Restore screen appears and the computer restarts.
After the computer restarts, click OK.
Thanks and have a good one.
Oliver
Jul 28, 2011 | Dell Inspiron 1501 Notebook
Okay. I have a Dell inspiron mini 10. I bought about a year and a half ago. I messed up when i spilled kool-aid on my computer, but i immediately turned it off, wiped off the stuff, opened up the innards...
Hi there!
The motherboard of your Dell Inspiron Mini 10 needs to be replace. If you don't have the Complete Care warranty, then Dell will not replace it for free. I suggest you contact Dell Technical Support and asked them how much it will cost to replace it. Also, check how much a new computer will cost and compare it to the price of replacing the motherboard. You can have an idea if its cheaper to replace the motherboard or to buy a new one.
Hope this helps
May 11, 2011 | Dell Inspiron Mini 10 Notebook
I have a Dell Inspiron 2650 laptop with operating system windows xp profesional. That happened after I downloaded a software called orbit downloadable. I went into my computer and clicked start,...
try to run windows f12 boot format it should be runing on f2 this way you can go straight to problem then asked to run windows again after you restart .
Feb 04, 2011 | Dell Inspiron 2650 Notebook
My Dell Inspiron laptop boot up freezes
RUN CHECK DISK AND IF IT STILL WONT BOOT RESTART AND BEFOR THE WINDOWS LOGO COMES ON PRESS F8 AND CHECK START IN SAFE MODE THEN RUN CHECK DISK
Nov 12, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 6400, asking for HDD password
Insert OS cd in drive and start reinstalling by selecting repair mode now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now you will come to old screen and previously configured desktop with all intact aplication and icons on desktop and it will no more ask you for password till you set a new one
Thanks and regards
Kindly rate this solution
Apr 04, 2009 | Dell Inspiron 6400 Notebook
Boots halfway and dies
One from all problems can be:
Hdd problem or power suply
If u have another hdd change it and try
Let me know if u got help?
Nov 27, 2007 | Dell Inspiron 1100 Notebook
Dell Inspiron 5160 Notebook Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
